BOSS R8002 RIOT 1600 Watt 2 Ch MOSFET Amplifier 2 Channel MOSFET Car Audio Amplifier
Brand:|Model: R8002|Part # 265-3985
The 1600 watt max, two channel RIOT R8002 Class AB amplifier from BOSS is an unbelievable value. Choose the R8002 for powering large subwoofers. 2-ohm stable, bridgeable, and tri-mode capable.
Part # 265-3985
  • BOSS RIOT Series amplifiers are some of the best values in car audio amplification
  • Much more dynamic, clear, and powerful than head unit amplification
  • 2 x 275W RMS power output
  • Class AB topology, MOSFET power supply, 2-ohm stable, and fully protected
  • Stealth black anodized aluminum chassis
If you're still using your head unit for amplification, you have no idea what you're missing! Head units are often unable to provide the loud, dynamic sound you want, and can distort (or even damage) your speakers at even medium volume levels.
That's where the BOSS RIOT Series of amplifiers comes in. Tried-and-true Class AB amplifier topology, 2-ohm stable (for powering a pair of 4-ohm speakers off a single channel), and way more than enough power for even the hungriest door, dash, or deck speaker. The R8002 can also be set up for 2.1 (tri-mode) use to power a pair of stereo speakers and a mono subwoofer (passive crossover values are listed in the manual).
BOSS built the RIOT Series amplifiers with advanced features that are usually associated with amplifiers at more than twice the price: thermal and short circuit protection, soft turn-on circuit, remote turn-on/off, nickel-plated low-level and high-level inputs, LED power and protection indicators, all housed in a stealth black anodized aluminum chassis.
The R8002 also includes a MOSFET PWM power supply (for 4-ohm bridged-mono operation), a variable 35 to 160 Hz low-pass crossover, selectable fixed 80 Hz high-pass crossover, a variable 0 to 18 dB bass boost, and a remote subwoofer level control for dialing in the perfect amount of bass from the driver's seat. Mounting hardware included.
Specifications: • Power output: 2 x 275W RMS (@ 4 ohms), 2 x 800W max (@ 2 ohms), 1 x 1600W max (4 ohms bridged-mono) • Frequency response: 9 to 50,000 Hz • Signal-to-ratio: >102 dB • Total harmonic distortion: 0.01% @ RMS power output • Damping factor: >125 • Dimensions (L x H x W): 10.43" x 2.25" x 14.33".
  • Input TypeRCA Line Level,Speaker Level
  • RMS Power Output (Per Channel 4 Ohms)275 Watts
  • Special Features2 ohm Stable,Bridgeable
  • Output Channels2
  • BrandBoss Audio Systems
  • ModelR8002
  • Part Number265-3985
  • UPC791489115278
  • Product CategoryProducts
  • Weight7.67 lbs.
View similar products to the BOSS R8002 RIOT 1600 Watt 2 Ch MOSFET Amplifier 2 Channel MOSFET Car Audio Amplifier
in the Products product category.
