BOSS R4004 RIOT 1600 Watt 4 Channel MOSFET Car Audio Amplifier
Brand:|Model: R4004|Part # 265-3990
The 1,600 watt max, four channel RIOT R4004 Class AB amplifier from BOSS is an unbelievable value. Choose the R4004 when moving door and dash speaker amplification from the head unit to a dedicated amplifier. 2-ohm stability for powering a pair of speakers per channel.
List Price$209.00
You Save48%
$108.37
Part # 265-3990
  • BOSS RIOT Series amplifiers are some of the best values in car audio amplification
  • Much more dynamic, clear, and powerful than head unit amplification
  • 4 x 150W RMS power output
  • Class AB topology, MOSFET power supply, 2-ohm stable, and fully protected
  • Stealth black anodized aluminum chassis
If you're still using your head unit for amplification, you have no idea what you're missing! Head units are often unable to provide the loud, dynamic sound you want, and can distort (or even damage) your speakers at even medium volume levels.
That's where the BOSS RIOT Series of amplifiers comes in. Tried-and-true Class AB amplifier topology, 2-ohm stable (for powering a pair of 4-ohm speakers off a single channel), and way more than enough power for even the hungriest door, dash, or deck speaker. The R4004 can also be set up for dual 2.1 (dual tri-mode) use to power two pairs of stereo speakers and two mono subwoofers (passive crossover values are listed in the manual).
BOSS built the RIOT Series amplifiers with advanced features that are usually associated with amplifiers at more than twice the price: thermal and short circuit protection, soft turn-on circuit, remote turn-on/off, nickel-plated low-level and high-level inputs, LED power and protection indicators, all housed in a stealth black anodized aluminum chassis.
The R4004 also includes a MOSFET PWM power supply (for 4-ohm bridged-mono operation), dual variable 35 to 160 Hz low-pass crossovers, dual selectable fixed 80 Hz high-pass crossovers, a variable 0 to 18 dB bass boost, and a remote subwoofer level control for dialing in the perfect amount of bass from the driver's seat. Mounting hardware included.
Specifications: • Power output: 4 x 150W RMS (@ 4 ohms), 4 x 400W max (@ 2 ohms), 2 x 800W max (4 ohms bridged-mono) • Frequency response: 9 to 50,000 Hz • Signal-to-ratio: >102 dB • Total harmonic distortion: 0.01% @ RMS power output • Damping factor: >125 • Dimensions (L x H x W): 10.44" x 2.25" x 15.51".
  • Input TypeRCA Line Level,Speaker Level
  • RMS Power Output (Per Channel 4 Ohms)150 Watts
  • Special Features2 ohm Stable,Bridgeable
  • Output Channels4
  • BrandBoss Audio Systems
  • ModelR4004
  • Part Number265-3990
  • UPC791489115223
  • Product CategoryCar Amplifiers
  • Weight9.55 lbs.
View similar products to the BOSS R4004 RIOT 1600 Watt 4 Channel MOSFET Car Audio Amplifier
in the Car Amplifiers product category.
