265-3778_ALT_0
265-3778_ALT_1
265-3778_ALT_2
BOSS PC65.2C PHANTOM 6-1/2" Component Speaker Set 500 Watt
Brand:|Model: PC65.2C|Part # 265-3778
Upgrade your car audio system's stock speakers with a set of 2-way, 6-1/2" Phantom Series PC65.2C component speakers from BOSS. Cast woofer baskets increase rigidity, while the frequency range is split among two speakers for increased clarity, bass, output, and power handling.
List Price$89.00
You Save42%
$51.39
Part # 265-3778
  • Curve-linear, poly-injected woofer cones with rubber surrounds
  • 1" silk dome tweeters in an adjustable housing
  • Custom passive crossovers for seamless driver integration
  • High sensitivity, high power handling
  • Two woofers and two tweeters in one package
  • Includes woofer grilles, wire, and mounting hardware
The PC65.2C Phantom Series component 2-way, 6-1/2" speaker set from BOSS is a great way to upgrade your stock car audio speakers and transform your OEM sound system from lackluster to lively.
BOSS builds each of the Phantom Series 6-1/2" woofers using a die-cast aluminum basket for great structural rigidity, and a injected-molded, polypropylene curve-linear woofer cone that is attached to a rubber surround for moisture resistance. The dust cap is removed, due to the unique cone shape, to sweep more air for increased bass performance.
1" silk dome tweeters are included for crisp, clean high frequency reproduction and are mounted in an adjustable housing for increased mounting options. Two 2-way passive crossovers seamlessly integrate the woofer and tweeter side together, for complete sonic accuracy. Grills, speaker wire, and mounting hardware included. Component set includes two woofers, two tweeters, and two crossovers.
Specifications: • Power handling: 125 watts RMS/250 watts peak (each side) • Impedance: 4 ohms • Frequency response: 65-22,000 Hz • SPL: 94 dB 1W/1m • Woofer dimensions: Overall: 6.5" diameter x 2.63" H, Mounting depth: 2.375".
  • BrandBoss Audio Systems
  • ModelPC65.2C
  • Part Number265-3778
  • UPC791489113939
  • Product CategoryComponent Speaker Systems
  • Unit of MeasurePR
  • Weight7.4 lbs.
View similar products to the BOSS PC65.2C PHANTOM 6-1/2" Component Speaker Set 500 Watt
in the Component Speaker Systems product category.
