BOSS MCK1470.6 Marine CD Receiver with Cover and 6-1/2" Speaker Pair Package
Brand:|Model: MCK1470.6|Part # 265-4682
The BOSS MCK1470.6 package includes an MP3-enabled MR1470UW marine digital CD receiver, an MRC5 waterproof radio cover, a pair of 6-1/2" MR60W marine speakers, and a dipole MRANT10 hideaway antenna to get your boat rocking in no time flat!
Part # 265-4682
  • A complete marine audio package with head unit and cover, speakers, and antenna
  • MP3-enabled MR1470UW digital media CD receiver
  • Water-resistant MR60W 6-1/2" speaker pair
If you are one of the millions of people that stream music from Pandora® and iHeartRadio apps on their smartphone, BOSS made the MR1470UW MP3-enabled marine digital CD receiver for you. The front-mounted 3.5 mm Aux input offers unlimited compatibility with the headphone output of nearly every Apple, Android, or Windows Phone smartphone and portable media players.
Music lovers that want to take their music with them aren't left out either... a USB port and SD/MMC card port allows you to load stored MP3 and WAV files directly into the BOSS MR1470UW. The tried and true AM/FM receiver, with 40 total station presets, has you covered if you are looking for a musical change of pace or to listen to talk radio. For security, the face plate is detachable and an MRC5 cover protects it from direct water contact. Remote control included.
This package also includes a pair of BOSS MR6W dual-cone 6-1/2" marine speakers that are built to withstand the harsh watercraft environment by using polypropylene injected 6-1/2" woofer cones, cloth surrounds, and a corrosion resistant frame.
Lastly, an MRANT10  41" long, marine-grade dipole antenna is included. It features a flexible rubber mast, that is easy to hide, and has a standard Motorola male connector.
MR60W Specifications: • Power handling: 100W RMS, 200W max • Sensitivity: 90 dB 1W/1m • Impedance: 4Ω • Frequency response: 80-20,000 Hz • Dimensions (Width x Height): 8" dia. x 4", Mounting depth: 2.44".
MR1470UW Features and Specifications:
  • Chassis Mounting: Single DIN
  • Detachable Front Panel
  • Monitor Display Format: Oversized, Active Black Mask Display
  • PLL Synthesized AM/FM Tuner
  • AM Stations: 6
  • FM Stations: 18
  • 24 Stations Preset
  • Switchable Radio Regions: USA, EUROPE
  • ID3-Tag
  • Disk Player Mechanism: MP3
  • Disc Player Compatible: MP3, CD, CDR, CDRW, WMA
  • USB Input: MINI Front panel
  • SD/MMC Memory Card Port Input: Behind Panel
  • AUX Input: Front panel
  • Audio RCA Output: 4
  • Illumination Controls
  • Preset Equalizer Selection Switch
  • Separate Bass and Treble Adjustment Control
  • Balance and Fader Adjustment Control
  • Mute
  • Stereo/Mono Selection Switch
  • Local Distance Switch
  • Loudness
  • Digital Clock Display
  • Auto Memory Store/Preset Scan Button
  • Last Position Memory
  • AMS (Auto Memory Search)
  • ESP (Anti Skip Mechanism)
  • 1-bit D/a Convertor
  • 8x Oversampling
  • Remote Control
  • Speaker Outputs Channels: 4
  • Total Output Power: 240 Watts
  • Mounting Depth: 7"
  • Compatible with Audio Output of iPod and other MP3 Players
  • PC Board with Conformal Coating
  • Front Panel UV Coating
  • 5 Volt Preamp Output
  • Fully Marinized
  • Dimensions (H x L x W): 2" x 6.75" x 7.13"
  • Speaker Type2-Way
  • Speaker Size6-1/2"
  • Power Handling (RMS)100 Watts
  • BrandBoss Audio Systems
  • ModelMCK1470.6
  • Part Number265-4682
  • UPC791489116077
  • Product CategoryMarine AM/FM Receivers
  • Weight10.65 lbs.
View similar products to the BOSS MCK1470.6 Marine CD Receiver with Cover and 6-1/2" Speaker Pair Package
in the Marine AM/FM Receivers product category.
