BOSS BRS52 5-1/4" Dual Cone Replacement Speaker
Brand:|Model: BRS52|Part # 265-382
5-1/4" dual polypropylene cone replacement speaker.
OUT OF STOCK
Due In: 2/12/2016
List Price$10.00
You Save42%
$5.85
Part # 265-382
Specifications: • Power handling: 30 watts RMS/60 watts max • Impedance: 4 ohms • Frequency response: 100 Hz - 18 kHz • Mounting depth: 1.9".
  • Speaker Size5-1/4"
  • Speaker TypeDual-Cone
  • Power Handling (RMS)30 Watts
  • BrandBoss Audio Systems
  • ModelBRS52
  • Part Number265-382
  • UPC791489110358
  • Product CategoryDash, Door & Deck Car Speakers
    (4 Reviews)
  • Weight2.15 lbs.
View similar products to the BOSS BRS52 5-1/4" Dual Cone Replacement Speaker
in the Dash, Door & Deck Car Speakers product category.
BOSS BRS52 5-1/4" Dual Cone Replacement Speaker is rated 3.75 out of 5 by 4.
Rated 4 out of 5 by from Very Nice for the MoneyI purchased two of these speakers for the dash of my 1983 Jeep CJ-5. The speakers appear to be well-made and the cone material should be durable. The sound is decent with not as much bass as I hoped, but for the price I am quite happy. As with everything made in China, I am skeptical about long-term durability. I guess only time will tell.
Date published: 2015-06-05
Rated 2 out of 5 by from Get what you pay forBought a set of these for my 1997 Jeep. Put one in and found it to have very little bass compared to factory speakers. Mid range was decent, top end also seemed weaker than the old factory speakers.Returning the remaining 3 to get something with a little more bottom-end.
Date published: 2014-05-30
Rated 4 out of 5 by from Better than OEM at a GREAT PriceThese were purchased to replace the speakers in a daily driver(beater) that i purchased. all 4 factory speakers had died long ago and i was in need of music for my drive. I put in a cheap JVC Head unit and 4 of these speakers.the sound is good. Better than most factory systems and the price is unbeatable. If you are looking for aftermarket sound quality by aftermarket style speakers. These are OE Replacement speakers. They wont deliver crushing bass or razor sharp highs but they do their job without frills or fuss. Good enough for my commute. For the most part sound reproduction is flat. They are very sensitive to their enclosure however so a bit of dynamat will go a long way with these.
Date published: 2013-07-10
Rated 5 out of 5 by from Great value car speaker!I bought a pair of these for front doors of 07 Toyo Highlander after buying many premium car speakers and finding the high end stuff to harsh at the high end or having too much midbass. I tested these (as I do all speakers) with soundeasy before installing, and they were quite flat/smooth in a replica of the car installation I have set up in my basement shop. Smooth from 100hz to just over 1k hz on axis, with slight rise from 1k to 4k ... on axis... then a dropout at around 8k where the whizzer doesn't have too much oomph. I used the dayton 4 ohm neo tweeter with a 2 ohm resistor in series, 3 mfd capacitor, and connected it out of phase with the woofer for a very flat resonse... off axis 45 degrees, which is the challenge of a door mounted speaker. I have a sub, and cross at 80hz. The bass is quite respectable, but don't expect sub like bass. These compare favorably with $60-100 per pair speakers... even more. All the big names.
Date published: 2012-05-09
  • 2016-02-08T06:34CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_265-382, PRD, sort_mostRecent
Are they 8 ohm ?
Asked by: Harrym
These are 4ohm speakers.
Date published: 2015-12-24
Is this speaker a good replacement for an old motorola AM car radio-6 volts-not sure of the ohms Motorola CY8-5 " -seperate speaker-2 wire. Thanks
Asked by: crosleyjon
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Answered by: MattW
Date published: 2015-06-30
What type of connector on the Boss MRS52? Will these work with my 1992 Honda Accord LX (rear speakers) has rectangular grey connector OEM. My current speakers say 30 watts, 4ohms, #20057, Made in USA. There are 3 holes for mounting.
Asked by: Huntsman
The terminals on this speaker are 0.205" and 0.110".
Date published: 2014-05-20
I Need a very plain black grill for these what would work.
Asked by: Anonymous
The closest option we offer would be below.
Date published: 2013-08-22
Is this driver coaxial?
Hello.Is this a coaxial driver?Thanks!
Asked by: nonsuchpro
This driver is closer to a full range than anything else. It uses a smaller cone inside the larger one to produce better highs. One coil with two cones. It looks like a good economical replacement to original equipment manufacturer units.
Answered by: bikermike
Date published: 2012-07-22
Is the surround made of rubber or foam, and if it is foam then is it treated with poly or some other type of anti-aging coating?
Asked by: Ludo
It is a foam surround, most likely treated with a UV inhibitor or similar. It is not heavily treated.
Answered by: RussR
Date published: 2011-06-23
  • 2016-02-08T07:18CST
  • co_hasquestionsanswers, tq_7
  • loc_en_US, sid_265-382, PRD, sort_recentQuestionsFirst
