BOSS B65N Speaker Level to Line Level Output Converter
Brand:|Model: B65N|Part # 265-4040
BOSS' 2-channel, adjustable B65N connects to a mobile audio head unit's speaker-level output and converts it to line-level RCA output, for use with line-level only mobile audio electronics like equalizers, active crossovers, and amplifiers. Great for adding powered subwoofers to OEM stereos!
List Price$12.99
You Save55%
$5.85
Part # 265-4040
  • Converts speaker output to line-level output
  • Small size and easy to install
  • Two output adjustments for gain matching
The adjustable B65N two-channel speaker-level to line-level converter (also called a high-to-low adapter), from BOSS, allows for the installation of line-level mobile audio electronics, such as amplifiers and active crossovers, into systems without a line-level signal by using the head unit's speaker output.
Great for adding powered subwoofers to OEM systems. Input sensitivity adjustments allow for fine-tuning the signals sent to amplifiers to prevent amplifier clipping and maximize amplifier output. Built-on mounting tabs facilitate permanent installation. Dimensions (L x W x H): 3.4" x 1.5" x 1.5".
  • BrandBoss Audio Systems
  • ModelB65N
  • Part Number265-4040
  • UPC791489170062
  • Product CategoryLine Output Converters & Controls
    (1 Reviews)
  • Weight0.25 lbs.
View similar products to the BOSS B65N Speaker Level to Line Level Output Converter
in the Line Output Converters & Controls product category.
BOSS B65N Speaker Level to Line Level Output Converter is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Works fineYeah it’s plastic, yeah it’s a bit hard to reach inside and adjust the attenuators – but it worked out just fine. Hooked up in parallel with my rears to enable an RCA for my Sub Amp inputs. – The amp had speaker level BUT I needed to add a pair of FMOD inline Low-Pass filters. All worked just fine.
Date published: 2013-12-09
  • 2016-02-05T06:23CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_265-4040, PRD, sort_mostRecent
What is the max input watts?
Asked by: john24
Unfortunately Boss does not specify the input power on this unit.
Date published: 2014-04-29
The color code chart for the input leads list both left and right as gray, but in the picture, I see green input wires. Which channel are the greens?
Asked by: Hifi_Tweeter
The left channel is green and green/white, the right channel is grey and grey/white. The conductor with the white strip is negative on both.
Date published: 2013-01-26
  • 2016-02-05T07:02CST
  • loc_en_US, sid_265-4040, PRD, sort_recentQuestionsFirst
