Bogen X600 Black Max Dual 70V Power Amplifier 600W x 2
Brand:|Model: X600|Part # 241-984
Bogen's Black Max amplifiers are designed to provide maximum performance in constant voltage speaker systems.
ORDER TODAY
Ships in 3-10 business days
List Price$2,187.04
You Save44%
$1,221.88
Part # 241-984
  • 600W RMS x 2 at 70V
  • Dual 70V amplifier channels
  • Low noise, low distortion, and high slew rate
  • High efficiency Class H amplifier design
  • Transformerless direct drive outputs
  • Pluggable terminal strips for input connections
  • Independent low-cut filters on each input
Bogen's Black Max amplifiers are designed to provide maximum performance in constant voltage speaker systems. High efficiency Class H amplifier design and auto-sleep feature reduce power consumption on continuously-powered systems. Rear-mounted volume controls, independent low-cut filters on each input, and pluggable input terminal strips were specifically designed for the fixed install market. Built-in power sequencing for controlling multiple Black Max amplifiers combats current in-rush problems of large audio systems. Massive power toroid and heat sinks, heavy 14-gauge chassis, Back-Slope™ AC voltage stabilization, clip limiters, and DC voltage, over-current, and thermal protection circuits make this a workhorse amplifier.
Specifications: Dimensions: 3-1/2" H. x 19" W. x 16" D.
Additional information:600W RMS x 2 at 70V • Dual 70V amplifier channels • Low noise, low distortion, and high slew rate • High efficiency Class H amplifier design • Transformerless direct drive outputs • Pluggable terminal strips for input connections • Independent low-cut filters on each input • Built-in power sequencing for multiple Black Max amp installations • DC, overload, short circuit, and thermal protection circuits • Clip limiting circuits for speaker protection • Power-saving sleep mode for intermittent use applications • Status, Signal, and Limit indicators • Back-SlopeTM AC voltage stabilization for dependable performance • Heavy-gauge steel chassis with cast aluminum front panel • Rear-mounted volume controls • Mounts in 2 rack spaces (3-1/2") • 2 independent, continuously-variable cooling fans for reliable and quiet operation  • Easily removable front fan grills with filters • Rear rack mount kit available separately.
  • Power Output (RMS @ 70V)> 400W
  • Weight Range50 to 59 lbs.
  • BrandBogen
  • ModelX600
  • Part Number241-984
  • UPC765368140019
  • Product CategoryCommercial Contractor Power Amplifiers
  • Weight54 lbs.
View similar products to the Bogen X600 Black Max Dual 70V Power Amplifier 600W x 2
in the Commercial Contractor Power Amplifiers product category.
I have a Bogen X350, but do not have the little green 3 screw connector plugs needed to connect the mike or other inputs to the amp. Do you at Parts-Express have them?
Asked by: cfh51
These are called phoenix connectors. We have them available but only in 4 conductor, you may have to do a search for the number of cunductors you need.
Date published: 2014-06-03
  • 2016-02-08T07:23CST
  • loc_en_US, sid_241-984, PRD, sort_recentQuestionsFirst
