Bogen X300 Black Max Dual 70V Power Amplifier 300W x 2
Brand:|Model: X300|Part # 241-980
Bogen's Black Max amplifiers are designed to provide maximum performance in constant voltage speaker systems.
OUT OF STOCK
Due In: 3/4/2016
List Price$1,720.14
You Save50%
$858.00
Part # 241-980
  • 300W RMS x 2 at 70V
  • Dual 70V amplifier channels
  • Low noise, low distortion, and high slew rate
  • High efficiency Class H amplifier design
  • Transformerless direct drive outputs
  • Pluggable terminal strips for input connections
  • Independent low-cut filters on each input
Bogen's Black Max amplifiers are designed to provide maximum performance in constant voltage speaker systems. High efficiency Class H amplifier design and auto-sleep feature reduce power consumption on continuously-powered systems. Rear-mounted volume controls, independent low-cut filters on each input, and pluggable input terminal strips were specifically designed for the fixed install market. Built-in power sequencing for controlling multiple Black Max amplifiers combats current in-rush problems of large audio systems. Massive power toroid and heat sinks, heavy 14-gauge chassis, Back-Slope™ AC voltage stabilization, clip limiters, and DC voltage, over-current, and thermal protection circuits make this a workhorse amplifier.
Specifications: Dimensions: 3-1/2" H. x 19" W. x 16" D.
Additional information:300W RMS x 2 at 70V • Dual 70V amplifier channels • Low noise, low distortion, and high slew rate • High efficiency Class H amplifier design • Transformerless direct drive outputs • Pluggable terminal strips for input connections • Independent low-cut filters on each input • Built-in power sequencing for multiple Black Max amp installations • DC, overload, short circuit, and thermal protection circuits • Clip limiting circuits for speaker protection • Power-saving sleep mode for intermittent use applications • Status, Signal, and Limit indicators • Back-SlopeTM AC voltage stabilization for dependable performance • Heavy-gauge steel chassis with cast aluminum front panel • Rear-mounted volume controls • Mounts in 2 rack spaces (3-1/2") • 2 independent, continuously-variable cooling fans for reliable and quiet operation • Easily removable front fan grills with filters • Rear rack mount kit available separately.
  • Power Output (RMS @ 70V)201W to 400W
  • Weight Range50 to 59 lbs.
  • BrandBogen
  • ModelX300
  • Part Number241-980
  • UPC765368140033
  • Product CategoryCommercial Contractor Power Amplifiers
    (2 Reviews)
  • Weight50 lbs.
View similar products to the Bogen X300 Black Max Dual 70V Power Amplifier 300W x 2
in the Commercial Contractor Power Amplifiers product category.
Bogen X300 Black Max Dual 70V Power Amplifier 300W x 2 is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Must have been designed for football fields!Two amps in one box, Home/Visitors, just a very good design for high school football/track fields. Channal A, Home with channel B for visitors and 70.7 volt and independent gain for each channel.Have installed 4 in HS football fields!
Date published: 2008-08-06
Rated 5 out of 5 by from Perfect for installationsI used these amps for permanent installations. They perform flawlessly and require very little maintenance. Just clean out the air filters from time to time. Otherwise you get a lot of bang for your buck.
Date published: 2007-11-05
  • 2016-02-07T06:50CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_241-980, PRD, sort_mostRecent
