Bogen DRZ35 4-Zone Music and Paging System with AM/FM Receiver
Brand:|Model: DRZ35|Part # 241-969
Bogen's DRZ35 AM/FM receiver provides you with all the power and paging system for small to medium sized applications. The unique 4-zone music and paging system features a low Z microphone input, and is compatible with 4 ohm, 25 or 75 volt speaker systems.
OUT OF STOCK
Due In: 7/31/2016
List Price$826.02
You Save47%
$434.89
Part # 241-969
  • Self-contained, 4-zone music and paging system
  • For use with 4-ohm, 25 or 70 volt speaker systems
  • Selectable 1 to 4 zones for music or paging
  • Microphone paging priority with VOX-activated music muting
  • Built-in digital AM/FM Tuner, with PLL synthesizer provides accurate frequency selection
The Bogen DRZ35 is a unique, self-contained 4-zone music and paging system for small to medium sized applications. It combines a digital AM/FM tuner with MIC, LINE, and AUX inputs. It has a 35-watt amplifier capable of driving 4-ohm speaker systems as well as 25 or 70 volt distributed systems. The DRZ35 allows you to connect up to four switch-selectable paging zones and features Bass and Treble controls and a Master Volume control with a 5-segment LED output meter. The built-in tuner uses a PLL synthesizer to provide accurate frequency selection. The MIC input can be set for VOX-activated muting of the other audio inputs. The microphone input accepts a balanced low Z microphone with selectable Phantom Power, and uses a three-pin standard mic connector with a separate volume control.
Specifications: • Power output: 35 watts • Distortion: <1% rated output power @ 1 kHz • Frequency response: 70 to 15,000 Hz (25/75V), 20 to 20,000 Hz (4 ohm) • S/N ratio: MIC -55 dB, LINE/AUX -70dB • Speaker outputs: 4 ohm, 25V, 70V • Power input: 120 VAC, 60 Hz • Dimensions: 17" x 5-1/4" x 13-5/8" • Weight: 20 lbs.
  • Power Output (RMS Per Channel @ 8 ohms)35 Watts
  • Output Channels4
  • Weight Range20 to 29 lbs.
  • BrandBogen
  • ModelDRZ35
  • Part Number241-969
  • UPC765368403374
  • Product CategoryReceivers & Tuners
  • Weight14.7 lbs.
View similar products to the Bogen DRZ35 4-Zone Music and Paging System with AM/FM Receiver
in the Receivers & Tuners product category.
