Bluetooth Module BT-1
Brand:|Model: BT-1|Part # 320-352
The BT-1 Bluetooth module adds a Bluetooth wireless audio receiver to nearly any device. Great for connecting the audio output of an iPad, tablet computer, or smartphone to your computer, receiver, or even your subwoofer, wirelessly.
  • Add a Bluetooth audio receiver to nearly any amplifier
  • Class 2 range of up to 15 meters (49.2 feet)
  • 16-bit A2DP support for true stereo output
  • Pre-attached USB A-Male for power
  • 3.5 mm stereo jack audio output
  • Bluetooth v1.2 compliant
The BT-1 module is designed to integrate wireless Bluetooth audio from smartphones, tablets, or laptops into speakers and subwoofers, car audio applications, and remote wireless amplifiers. Additionally, this module may be used to create a wireless link between a Bluetooth source and a traditional amplifier, receiver, preamplifier, or mixer.
Features of this Bluetooth v1.2 compliant receiver module include a small 2" x 1-1/2" form factor, a Class 2 range of up to 15 meters (49.2 feet), and 16-bit A2DP support for true stereo output. A USB A-Male plug and a stereo 3.5 jack are pre-attached to the module for quick connection and use. The USB A-Male plug is used as a power connection drawing 5 VDC off of the USB bus from a computer or powered USB hub.
Specifications: • Supply voltage: 3.3 to 5.0 VDC • Supply current: 50 mA • Operating frequency: 2.4 to 2.483 GHz • Bluetooth specification: v1.2 • Output power class: Class 2 • Receiver sensitivity: -80 dBm • Output level: 1V RMS • Output impedance: 1k ohm • Frequency response: 20-20,000 Hz (-3 dB) • Sampling: 44.1 kHz, 16-bit • Signal-to-noise ratio: 70 dB • THD: < 0.1% @ 1 kHz • Dynamic range: 85 dB • Channel separation: 65 dB • PCB dimensions: 2" W x 1-1/2" L • USB cable length: 18" • Audio output cable length: 18".
Note: This device only receives stereo Bluetooth audio. This device does not transmit a Bluetooth signal.  The Sync/Pair button (as depicted in the manual) has been removed from the module as it was not necessary. The instructions have been amended to reflect this change.
  • Project Kit TypeAmplifiers & Audio
  • BrandParts Express
  • ModelBT-1
  • Part Number320-352
  • UPC844632095849
  • Product CategoryElectronic Project Kits
    (34 Reviews)
  • Weight0.1 lbs.
View similar products to the Bluetooth Module BT-1
in the Electronic Project Kits product category.
Part # 320-352
