Black Rubber Cement Speaker Repair Glue 1 oz. Bottle
Brand:|Model: BC-1|Part # 340-078
BC-1 black rubber cement attaches paper, plastic, and metal dust caps to most speaker cones, and is also handy for gluing spiders, surrounds, and gaskets to speaker frames.
List Price$12.99
You Save39%
$7.95
Buy 4+$7.55
Part # 340-078
  • Solvent-based high solids rubber cement
  • Black color is suitable for many cosmetic uses
  • High tack and strength make BC-1 ideal for gluing spiders and surrounds to frames
  • Glues paper, poly, or metal dust caps to almost any cone
BC-1 speaker repair glue is a specialized black rubber cement intended for spider to frame, surround to frame, and gasket to frame adhesion. Its fast setup and medium viscosity are ideal for attaching dust caps of almost any composition to cones of almost any composition. Also works great when attaching surrounds to poly cones. Solvent-based with high solids concentration. 1 oz. container. Use of an applicator bottle is highly recommended, sold separately.
  • BrandParts Express
  • ModelBC-1
  • Part Number340-078
  • UPC844632091728
  • Product CategorySpray Adhesive & Glue
    (6 Reviews)
  • Weight0.05 lbs.
View similar products to the Black Rubber Cement Speaker Repair Glue 1 oz. Bottle
in the Spray Adhesive & Glue product category.
Black Rubber Cement Speaker Repair Glue 1 oz. Bottle is rated 4.5 out of 5 by 6.
Rated 4 out of 5 by from worksworked on 2 thiel cs1.2 lower speakers.manufacturer wanted 450.00 plus shipping and tax. this worked fine for about 2 weeks for 12.00.
Date published: 2014-08-27
Rated 4 out of 5 by from Good Product, but small bottle and no applicatorVery small bottle, just enough to do a 15" Woofer.The product itself works well, no complains.Including an applicator tip would make a job a lot cleaner.
Date published: 2014-03-02
Rated 5 out of 5 by from Very hard to find stick to almost anythingVery hard to find adhesive stick to almost anything.stuck to poly dust cap and cone when nothing else would like superglue, epoxies, gorilla glues.
Date published: 2014-01-31
Rated 5 out of 5 by from Works as advertisedI used this glue to partially reattach a rubber surround on a twenty year old woofer. I used a small artist's paintbrush and a toothpick to spread the glue. It handles easily and dries rapidly. I would suggest masking any and everything you don't want to glue as you could quickly make a mess of things. The repaired speaker works perfectly!
Date published: 2013-03-13
Rated 4 out of 5 by from This stuff worksA fine working adhesive. I wish it came with an applicator tip. Projects would be neater that way.
Date published: 2013-03-01
Rated 5 out of 5 by from GREAT PRODUCT, BIG PORFORMANCE, SMALL BOTTLE BUT..........OK SO I USED IT IN A JOB I HAD AND I WORKED FLAWLESS..... AWESOME RUBBER CEMENT I MUST SAY, BUT THE BOTTLE IS SO SMALL NOT GOOD FOR ME IF I USE LIKE HALF A BOTTLE TO A FULL ONE ON BIG JOBS GET A BIGGER BOTTLE 16OZ LIKE THE WET LOOK SIZE MUCH BETTER EVERYTHING ELSE WAS A1 PERFECT TO BAD FOR THE SIZE GOOD ONE PARTS EXPRESS A1 10 POINTS FROM SYDNEY AUSTRALIA :)
Date published: 2012-08-31
  • 2016-02-06T06:43CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_340-078, PRD, sort_mostRecent
Where can I find the Technical data sheet for this product? I need to know curing time and the best solvent for cleanup.
Asked by: Tony68
We only have the MSDS available for this product which you can see below.www.parts-express.com/pedocs/more-info/340-078--bc-1-rubber-cement-msds.pdf
Date published: 2015-09-21
Is this the best or correct glue to use to reattach a black *rubber* (not foam) surround to a metal speaker basket? (I have a bad section approx. 3" long)... also, what do I use to clean both the surfaces with?
Asked by: ssouci
Yes this will work fine for that application. We recommend isopropyl alcohol and wire brushes for cleaning the metal surfaces.
Date published: 2015-08-14
I have a Kicker CVX and around the edge of the surround it has come loose from the metal in a couple of small spots, would this work to fix it? Thanks
Asked by: Doomsday74
Yes this will work for that application.
Date published: 2014-10-20
Is it flexible when dry? Need to fix small tears in my rubber surround.
Asked by: nazalv56
Your best bet for small tears in a rubber surround is actually a bicycle tube repair kit. This glue will dry too hard for a surround repair.
Date published: 2014-05-29
how long this glue will be usable, and how and where to keep it when it is not used.
Asked by: boggy
This glue will only have a shelf life of about 3 months before it starts to solidify.
Date published: 2015-03-28
will it work on a port
will this glue work on a plastic precision port for gluing the flares to the tube
Asked by: dwal
It would work, but you could also use any plain old CA or super glue also.
Answered by: mtg90
Date published: 2012-02-15
  • 2016-02-06T08:01CST
  • co_hasquestionsanswers, tq_7
  • loc_en_US, sid_340-078, PRD, sort_recentQuestionsFirst
