303-410_ALT_0
BIC Venturi DV32CLR 2-Way MTM Center Channel Speaker
Brand:| Model: Venturi DV32CLR
BIC's Venturi DV32CLR center speaker uses two 3-1/2" poly/graphite cone woofers with massive magnet structures—resulting in clean, accurate bass with crisp dialogue performance, even at high volume levels!
  • D'Appolito design with two 3-1/2" poly/graphite woofers
  • 1/2" poly dome tweeter
  • Shielded design
  • Gold plated speaker push terminals
  • 7-year warranty
303-410
Weight: 6 lbs.
IN STOCK
List Price$99.00
You Save57%
$42.90
Part # 303-410
BIC's Venturi DV32CLR center speaker uses two 3-1/2" poly/graphite cone woofers with massive magnet structures-resulting in clean, accurate bass with crisp dialogue performance, even at high volume levels! A center-mounted poly dome tweeter extends to high frequencies beyond audible range. The black ABS plastic enclosure has been molded for placement on a shelf, entertainment center, or HDTV stand. BIC Venturi DV32 satellite speakers are a perfect match to the DV32CLR center speaker. Sold individually.  7 year parts and labor.
Specifications: • Recommended power: 5-125 watts • Frequency response: 75-20,000 Hz (± 3 dB) • Sensitivity: 90 dB @ 1W/1m • Impedance: 8 ohms • Dimensions: 4-5/8" H x 10-3/4" W x 6" D.
  • Input Rating8 ohm
  • Woofer Diameter3-1/2"
  • Configuration2-way (MTM)
  • ColorBlack
  • BrandBIC America
  • ModelVenturi DV32CLR
  • Part Number303-410
  • UPC729305001306
  • Product CategoryCenter Channel Speakers
    (4 Reviews)
  • Weight6 lbs.
View similar products to the BIC Venturi DV32CLR 2-Way MTM Center Channel Speaker
in the Center Channel Speakers product category.
BIC Venturi DV32CLR 2-Way MTM Center Channel Speaker is rated 4.75 out of 5 by 4.
Rated 5 out of 5 by from Center speakerThe BIC Venturi center speaker is the final piece to my Hi-End home theater A/V system. Though I was skeptical about its small size it does a great job. fyi: my system includes Marantz AV-separates with a 5ch Amp and 2 mono Amps for the front Magnepan 1.6QR speakers.
Date published: 2013-09-01
Rated 4 out of 5 by from Great value!!! A true home run.The speaker is much better than the price would indicate. I was in a crunch for space between my fireplace mantle and the bottom of the flat panel TV and this speaker just fit. There is a very slight nasal character to the voices and you really can't be too far off axis or the highs drop off pretty fast. For the money and size, it really is a home run though. I have it matched with a subwoofer using an auto calibrated surround sound receiver and the sound is really not lacking much. I can't say how things would sound if there was not any eq to the speaker, as in my case, but you could say that about almost any speaker, even my much larger and much more expensive NHT center channel. If needed, I thought I could just replace it with a newly designed thin Polk center channel at over 3 times the price but I don't think it would be worth it. This speaker is that good.
Date published: 2010-12-08
Rated 5 out of 5 by from Great productFor the price the sound clarity is exceptional, one of the best products I have ever purchased
Date published: 2010-02-01
Rated 5 out of 5 by from GREAT ADDITON TO MY SOUND SYSTEMI have a 6.1 channel surround system but when I originally purchased my surround speakers the set was for a 5.1 channel. The cost of those speakers was within my budget so i did not have the extra center channel speaker. So I've been looking for a center speaker to compliment the size speakers I have so it doesn't look out of place. This speaker fit my budget as well as looks great with the other Jenson speakers I have. The sound is fantastic. It has brought more bass into my system as well as better center sound overall. The original center speaker is now the rear center speaker. This one is the front channel center. My sub-woofer had bass but we never felt that bass feeling like you should feel in a surround sound. We do now. After looking a long time for center speaker that fit my criteria this one has exceeded it. I could not find one anywhere else to come close and I got free shipping on top of it. I have shopped with you before and have recommended you to all my friends. Thank you very much. Larry
Date published: 2009-12-17
  • 2015-03-28T07:19CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_303-410, PRD, sort_mostRecent
mounting BIC center channels
can BIC DV 32 or 52 center be mounted to wall/other via back or top? what would I need to do it?
Asked by: scottinbardstown
This product (and the majority of BIC center channels, to my knowledge) is not designed to be wall mounted. A shelf or modification to the cabinet would be required.
Answered by: RussR
Date published: 2012-03-08
  • 2015-03-28T07:24CST
  • loc_en_US, sid_303-410, PRD, sort_recentQuestionsFirst
Customer projects that include: BIC Venturi DV32CLR 2-Way MTM Center Channel Speaker
