BIC Venturi DV32-W 3-1/2" 2-Way Bookshelf Speaker Pair White
Brand:|Model: Venturi DV32-W|Part # 303-401
BIC's elegant 2-way DV32 bookshelf speaker simply outperforms many speakers—regardless of size and price.
Part # 303-401
  • Gold plated push terminals
  • 7-year parts and labor warranty
  • 3-1/2" poly/graphite woofer
  • 1/2" poly dome tweeter
  • Shielded design
BIC's elegant 2-way DV32 bookshelf speaker simply outperforms many speakers-regardless of size and price. A 3-1/2" woofer with poly/graphite cone is backed by a massive magnetic motor structure and is mated to a 1/2" poly dome tweeter. Expect surprising bass, buttery smooth midrange, and crystal clear highs making this speaker ideal for use with ALL music formats&, even surround sound. Extensive shielding prevents stray magnetic flux that typically interferes with CRT-based televisions and monitors. On the back of the DV32 cabinet are three different mounting keyholes that enable easy wall or corner placement without having to purchase extra mounting brackets. The DV32CLR center speaker is a perfect match to the DV32. Sold in pairs. 7 year parts and labor.
Specifications: • Recommended power: 5-125 watts • Frequency response: 80-20,000 Hz (± 3 dB) frequency response • Sensitivity: 90 dB @ 1W/1m • Impedance: 8 ohms • Dimensions: 7" H x 4-7/8" W x 4-1/8" D.
  • Input Rating8 ohm
  • Woofer Diameter3-1/2"
  • Configuration2-way
  • ColorWhite
  • BrandBIC America
  • ModelVenturi DV32-W
  • Part Number303-401
  • UPC729305001283
  • Product CategoryBookshelf Speakers
  • Unit of MeasurePR
  • Weight6.45 lbs.
View similar products to the BIC Venturi DV32-W 3-1/2" 2-Way Bookshelf Speaker Pair White
in the Bookshelf Speakers product category.
