303-468_ALT_0
BIC RtR-EV15 15" Biampable Floor Speaker
Brand:| Model: RtR-EV15
With a woofer magnet twice the size of the RtR1530 magnet, 95 dB sensitivity, and an extremely wide and level response range, BIC's RtR-EV15 sets a new high in performance to price ratio.
  • 15" double-ported bi-ampable floor speaker
  • One high excursion custom Eviction Series 15" woofer with high power
  • Heavy duty magnet
  • One sealed back 5-1/4" wide dispersion midrange
  • One high efficiency horn tweeter with extended output to 20 kHz
  • Features gold-plated terminals
  • Five year manufacturer's warranty on parts and labor
303-468
Weight: 72 lbs.
IN STOCK
List Price$399.00
You Save30%
ShippingTRUCK ONLY
$278.00
Part # 303-468
With a woofer magnet twice the size of the RtR1530 magnet, 95 dB sensitivity, and an extremely wide and level response range, BIC's RtR-EV15 sets a new high in performance to price ratio. Outstanding power-handling capability. It will accept the output of powerful amplifiers without a whimper and look great while doing so. There are some occasions when it is advantageous to drive the woofer separately from the mid-range and tweeter. This process of bi-amplification is enabled by two sets of gold-plated input terminals, one set connected to the woofer circuit and the other to the crossover circuit for the mid speaker and the horn tweeter. Gold-plated removable straps connect the two sets of inputs for conventional single-amplifier operation. 5 year parts and labor.
Specifications: • Power handling: 225 watts RMS, 430 watts peak • Frequency response: 24 Hz-20 kHz (+/-3 dB) • Sensitivity: 95 dB @ 2.83V 1W/1m • Impedance: 8 ohms • Dimensions: 43" H x 17-1/2" W x 12-1/2" D.
  • Input Rating8 ohm
  • Woofer Diameter15"
  • Configuration3-way
  • ColorBlack
  • BrandBIC America
  • ModelRtR-EV15
  • Part Number303-468
  • UPC729305004222
  • Product CategoryFloor-Standing & Tower Speakers
    (3 Reviews)
  • Weight72 lbs.
View similar products to the BIC RtR-EV15 15" Biampable Floor Speaker
in the Floor-Standing & Tower Speakers product category.
BIC RtR-EV15 15" Biampable Floor Speaker is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Excellent speakers for the moneyThese speakers are accurate & very efficient. They also sound great at higher volumes. Considering they have horn tweeters, the upper treble is very smooth but I found I need to cut 900hz, 1.6khz, 3khz & sometimes 5khz a couple dbs each when listening to hard rock. However with modern jazz I need no eq. With a few dbs of boosting in the bottom end, they're right on point.
Date published: 2012-04-04
Rated 5 out of 5 by from Very good valueDo not feel the difference in the sound intensity of A and lowest E on bass guitar - claim of 24 Hz at -3 Db seems to be right on the money. The higher sensitivity on high frequencies does not seem necessary but you can quell it on the amplifier.Overall most probably the best acoustics for the money. Much better lows than with old speakers of 70s - 90s with exclusion of high-priced ones maybe.
Date published: 2012-01-17
Rated 5 out of 5 by from Best RtR yet!I owned the previous RtR-15s and these are much better. Horn helps the highs that weren't there before and I really like the fact that they are bi-ampable. The paint is also a darker black, looks better in my room than the others.
Date published: 2011-09-20
  • 2015-05-22T10:19CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.3
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_303-468, PRD, sort_mostRecent
I have 2 Yamaha s115V pro speakers thru crown stereo rack amp & Mackie mixer. Can the BIC speaker function as a Sub by connecting only sub side of this speaker? The mixer could limit the frequencies, yes? System for home and band.
Asked by: Masterofspacetime
Technically these could be wired this way, although I would only recommend it for home applications. They would not last long in a live or pro sound setting.
Date published: 2015-04-29
I want to Bi-Amp these speakers. I will be using Kenwood Basic M2 220watts RMS@8ohm for the woofer and Kenwood KM-106 150watts RMS@8ohm for mid/tweeter. In Bi-Amp setup does the woofer and mid/tweeter still see an 8ohm load or does it see a 4ohm load? THX
Asked by: VusstoppyPro1
Each speaker is specified at 8 Ohms.
Answered by: TomI
Date published: 2015-03-23
Would I be able to hook this speaker right up to my stereo reciever powering each with 200 watts rms with the bass turned up all the way? Or would I have to add a crossover myself or bi amp them with separate crossed over amps?
Asked by: ShaneU
Yes these will work plugged into a standard receiver, they do not have to be bi-amped. You would not need a separate crossover if bi-amped, they would just require two stereo amps, or four mono amps for this application. I cannot say whether they will handle a ton of output with the bass turned all the way up, this will always limit the speakers output capability and its generally not recommended at higher volume levels.
Date published: 2014-10-17
On the woofer, what size is the voice coil and how much is the "throw" in inches and under shipping what does "truck only" mean
Asked by: BuckNut68
Unfortunately the manufacturer does not specify the voice coil size or Xmax on the woofer. You may be able to contact BIC directly for more information.
Date published: 2014-03-21
Cabinet Details?
Please provide details on the cabinet construction:- bracing, if any- material type- material thickness- dampening material thickness
Asked by: quarterturn
BIC is an excellent company. Although the catalog page does not specify, I am sure it meets or surpasses what is industry standard.The speaker has teinals for full range or, rove a jumper ans go bi-amp.
Answered by: Nitnub
Date published: 2013-09-08
Can I run these speakers with a full range or straight signal from my receiver/amp?
Just wondering if I can run these in a full range set up without the need for a crossover or any filter type thing.
Asked by: Kaygun
Yes, the great thing is that you can run th full range and of your need increases, buy a crossover and another amp for the sub and biamp.
Answered by: Nitnub
Date published: 2013-08-19
  • 2015-05-22T10:24CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.3
  • co_hasquestionsanswers, tq_11
  • loc_en_US, sid_303-468, PRD, sort_recentQuestionsFirst
Customer projects that include: BIC RtR-EV15 15" Biampable Floor Speaker
Customers Also Bought
