BES CON100 Installer Kit
Brand:|Model: CON100|Part # 365-500
The BES CON100 kit provides any general installer all the tools that they would need to pull wire.
Part # 365-500
The BES CON100 kit provides any general installer all the tools that they would need to pull wire. The installer kit includes the following: Five 6' Fiberfish pull rods (30' total) w/ case: Four of the pull rods have a male connector on one end and a female connector on the other which can be connected together. The fifth pull rod has a female connector on one end and bullnose at other. One 1/2"x 72" auger piranha bit: This unique bit has a replaceable cutting head so you don't have to throw out the entire bit when it gets dull. One 3/8" x 72" HSS piranha bit: This is a superior quality M-2 high speed steel drill bit that is welded to a flexible shaft. It has the ability to cut through both metal and wood, so there is no need to worry about hidden nails or metal studs when drilling. 20' fiberglass telepole: A telescoping wire pulling rod that allows you to push or pull wires over long spans. It is made of non-conductive fiberglass for safety and has an innovative lever lock system to lock the sections at any length. Attachment kit: This universal attachment kits offer all the different wire pulling tips that you could ever need. It includes: (1) FishHook, (1) Directional Tool, (1) Magnet Head, (1) Pull Ring, (1) Ball Chain, and (2) replacement tips. One expandable carrying case: This expandable carrying case is perfect for storing all your wire pulling tools. It collapses down to 60" and extends to 96" to be able to accommodate even the longest tools.
  • BrandBES
  • ModelCON100
  • Part Number365-500
  • UPC742585991006
  • Product CategoryWire Pulling Kits
    (1 Reviews)
  • Weight30.0001 lbs.
View similar products to the BES CON100 Installer Kit
in the Wire Pulling Kits product category.
Part # 365-500
