Buyout Special
189-276_ALT_0
189-276_ALT_1
Belkin Component Video and RCA Audio Cable Kit 6 ft. Supports 720p and 1080i HD Signal
Brand:| Model: AV22111-06-PDQ
This kit provides ideal connections for your HDTV and progressive scan DVD players, gaming consoles, VCR, Tivo, and other DVR systems, and satellite receivers. Offers a One Box solution for high quality audio and video connections.
  • Abrasion resistant flexible PVC jacket
  • Corrosion Resistant 24kt Gold Plated connector
  • Tinned Copper Braided Video Shielding
  • Precision machined 6 cut RCA connector with split center pin
  • One box solution for HD Audio and Video
189-276
Weight: 1.25 lbs.
IN STOCK
List Price$17.99
Regular Price$12.00
You Save86%
Special Price
$1.65
Buy 10-99 $1.39
Buy 100-up$0.95
Part # 189-276
Belkin's Pure AV cables let you experience cleaner, sharper, more accurate audio and video pictures and sound by using advanced engineering methods and the highest quality materials. PureAV Cables isolate your signal from interference to deliver the purest sound and picture. This kit provides ideal connections for your HDTV and progressive scan DVD players, gaming consoles, VCR, Tivo, and other DVR systems, and satellite receivers. Offers a One Box solution for high quality audio and video connections. 6ft.
  • Cable TypeComponent Video
  • Special FeaturesWith RCA Stereo Audio
  • Cable Length6 ft.
  • Jacket ColorBlack
  • BrandBelkin
  • ModelAV22111-06-PDQ
  • Part Number189-276
  • UPC722868646137
  • Product CategoryComponent Video Cables
    (6 Reviews)
  • Weight1.25 lbs.
View similar products to the Belkin Component Video and RCA Audio Cable Kit 6 ft. Supports 720p and 1080i HD Signal
in the Component Video Cables product category.
Belkin Component Video and RCA Audio Cable Kit 6 ft. is rated 5.0 out of 5 by 6.
Rated 5 out of 5 by from I love Parts-Express!I've been purchasing products from this company for a long time. And once again, I am not disappointed! These cables are the best you can buy and the price is unique. I will always shop at this site until I run out of money!!!! Thanks Parts-Express.
Date published: 2014-02-12
Rated 5 out of 5 by from Awesome cablesThese are great cables :Audio cable is very well built with quality real gold plated ends. The cable is very elastic.  Video cable is a little more stiff but still very elastic. You cant go wrong with these.
Date published: 2014-01-14
Rated 5 out of 5 by from Excellent cable for the priceI purchased this cable a year ago due to issues with a much inferior cable.  I wasn't expecting much for the price but was pleasantly surprised when they arrived.  The connections are tight and the cables are approximately 2-3 times thicker than a cable that can be bought at your local Walmart.  They got rid of a pixelation problem on the TV and actually improved from what I had before the problem started.  I will be buying more when I have the need!
Date published: 2014-01-09
Rated 5 out of 5 by from Can't beat the value of this set of cables!I am restoring a 30 year old stereo system consisting of a number of pieces of equipment. I didn't wont to use the old cables they were old and stiff. This seemed like such a great buy I bought several for just the audio cables they were better that the others out there and I didn't need real long cables. Well I quickly found that I could use the additional video cables for the stereo equipment and it worked just fine.This really made it an excellent value. I am happy as can be and I would easily recommend them to a friend.
Date published: 2012-12-10
Rated 5 out of 5 by from very good productsI received shipment in good order however I havn`t used these item yet. I am waiting on AT&T to install new U-serve system at which time I will put touse.I have used Belkin products often and I know theywill be fine.NormanE. Tooley
Date published: 2013-06-28
Rated 5 out of 5 by from Great Product, an even better valueBelkin Pure A/V,over the last 5 years or so I have found this to be a high quality product line.I have tested it against other products and find in most cases this is the best value. I have used many cables over the years and I still use in some cases, ones that cost less and ones that cost more. Depends on what you are doing, but if a person I know asks me to connect up an A/V system this would be my interconnect choice.I have never used the HDMI in this line but everything else.
Date published: 2011-07-23
Can the shell be removed and replaced on the plug connector itself? In other words, can they be disassembled and reassembled?
I plan to remove the cable and replace it with resistors in stereo pairs for adjusting cartridge loading for a turntable using the Y adapter below. Basically, I'm looking for quality, inexpensive RCA Plugs. If they can be disassembled, this looks like the ticket.
Asked by: Zach C.
I have these installed in our workout room. I looked at them and don't think it would be a good idea to disassemble these. They look "sealed" and would be very difficult, just my opinion. The good news is these are relatively inexpensive, so if you butcher them, not out a lot of money.
Answered by: Rookie in Plano
Date published: 2011-12-13
Customer projects that include: Belkin Component Video and RCA Audio Cable Kit 6 ft. Supports 720p and 1080i HD Signal
