Behringer XENYX XL1600 16-Input 4-Buss Live Mixer
Brand:|Model: XENYX XL1600
With the XENYX XL1600 mixer you can connect up to 16 microphones (or other mono instruments) and up to four stereo instruments. You also get four buses, allowing you to assign multiple channels—say all the mics on a drum kit or all the backup singers' mics—to a single fader.
List Price$749.99
Regular Price$499.99
You Save20%
Sale Price
$398.00
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
Behringer HPM1000 Multi-Purpose Headphones
Qty: 1Part # 248-6248
List Price:$14.99
Part # 248-6490
  • Ultra-low noise, high-headroom analog mixer
  • 12 state-of-the-art XENYX Mic Preamps plus 4 stereo Line inputs with ultra-high RFI suppression
  • Neo-classic "British" 4-band EQs with 2 semi-parametric mid bands for warm and musical sound
  • 4 Subgroup outputs with inserts plus 2 independent main outputs with inserts on Main A
  • 6 Aux sends per channel: 4 pre/post fader switchable for flexible routing
  • Channel inserts and direct outputs on each mono channel
  • Clip and Signal LEDs plus 80 Hz, EQ, Mute, Solo, Subgroup and Main routing switches on all channels
Some manufacturers can be sneaky when they tell you how many inputs their mixers have, counting features like CD/TAPE IN as an input. The XL1600 really gives you 8 mono channels and four stereo channels (with two 1/4" inputs apiece—an additional 8 line-level inputs (which can also be used for 4 additional mono mic channels), making it easy to accommodate a wide variety of live performance configurations. With this XL mixer you can connect up to 8 microphones (or other mono instruments) and up to four stereo instruments (keyboards, for example). You also get four buses, allowing you to assign multiple channels—say all the mics on a drum kit or all the backup singers' mics—to a single fader.
Best of all, you don't need a black belt in engineering to operate the XL series. To get started, assign all mics and instruments to their channels by connecting them to the corresponding jacks on the back panel. Now, get ready to quickly become acquainted with the XL series' incredibly user-friendly design.
Plenty of channels, all in living color
All dials on the XL series are assigned to colors that not only allow you to easily locate each function, but to also quickly identify corresponding faders. At the top of each mono channel strip, you’ll find a TRIM dial (white) for adjusting input gain and an 80 Hz switch that can eliminate unwanted infrasonics such as mic-handling noise. Each mono channel has a 4-band EQ (High, High Mid, Low Mid, Low). High Mid and Low Mid dials (blue) are each paired with a FREQ control (lighter blue) that allows you to select the frequency boosted or cut. Directly below the EQ, there’s an EQ switch allowing you to switch between processed and unprocessed signals.
What the heck is "British EQ?"
British EQ is a smashing thing to have on your side when you start reaching for those channel equalization knobs at a live concert or in the studio. The EQ's on British consoles from the 60s and 70s are what many engineers believe does their sound the best justice. When it comes to tweaking your sound, they're kind, gentle and above all, musical. It's like drinking a fine scotch instead of fortified wine—or maybe receiving a warm hug instead of a kick to the crotch.
British EQ's distinct configuration of wider curves/lower Q and harmonic phase characteristics allows you to add or subtract EQ more generously than you can with conventional EQ circuit designs. When you add low midrange, you get a firmer sound instead of a nasty bonk. When you back high frequencies off a bit, treble backs off just a hair instead of turning muffled.
Specifications: • Dimensions: 7.1" H x 21.3" x W x 19.5" D • Weight: 25.8 lbs.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • XLR Mic Inputs10 to 14
  • BrandBehringer
  • ModelXENYX XL1600
  • Part Number248-6490
  • UPC4033653021104
  • Product CategoryMixers - Live Sound & Recording
  • Weight26.5 lbs.
View similar products to the Behringer XENYX XL1600 16-Input 4-Buss Live Mixer
in the Mixers - Live Sound & Recording product category.
