Behringer XENYX X2222USB 22-Input 2/2-Bus Mixer w/ FX & USB
Brand:|Model: XENYX X2222USB|Part # 248-6608
How about eight XENYX mic channels with inserts, dedicated compressors, 3-band EQ with semi-parametric mids and three Aux Sends? You get all that with the X2222USB, plus four stereo line-level channels, two convenient mix subgroups and onboard 24-bit digital FX processing.
List Price$374.99
You Save33%
$249.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
Part # 248-6608
  • Premium ultra-low noise, high headroom analog mixer
  • 8 state-of-the-art, phantom-powered XENYX Mic Preamps comparable to stand-alone boutique preamps
  • 8 studio-grade compressors with super-easy "one-knob" functionality
  • Neo-classic "British" 3-band EQs with semi-parametric mid band for warm and musical sound
  • New studio-grade FX processor with 16 editable presets including reverb, chorus, flanger, and delay
  • Built-in stereo USB/Audio Interface to connect directly to your computer
  • Free download of Tracktion music production software
XENYX USB Series mixers are designed to handle your live gigs, and they provide the state-of-the-art tools you need to make stunning, professional-quality recordings. Along with their built-in USB/audio interfaces, XENYX USB mixers come with all the recording and editing software you'll need to turn your computer system into a complete, high-performance home recording studio .All this and more enclosed in a rack-ready, roadworthy steel chassis.
Sonically Superior Mic Preamps
All XENYX mixers have one thing in common—great-sounding, high headroom XENYX mic preamps. These state-of-the-art mic pres represent a major step in the evolution of audio technology—and they can easily hold their own, even when compared to the most expensive stand-alone mic preamps. XENYX preamps offer a staggering 130 dB of dynamic range, with a bandwidth that extends from below 10 Hz to well above 200 kHz. Armed with these outstanding mic preamps, XENYX mixers provide such transparent, crystal-clear performance you just might think someone upgraded your mics while you weren’t looking.
One-Knob Compression
Ask professional sound engineers what their favorite piece of external processing gear is and the majority response will be virtually unanimous—dynamic compression. What is compression? We're glad you asked. Compression essentially limits the dynamic range of a signal, lowering the level of loud sounds and turning up softer sounds, to achieve sonic balance. But applying compression is a delicate art that many novice, and even intermediate, sound techs have great difficulty mastering. "One-knob" compression is available on all mono channels and is easy to operate, even for entry-level users. With this one knob, you can easily dial in the perfect amount of compression for instruments and vocals, creating powerful mixes with punch and clarity. This is indeed a rare feature for products in this class—but standard on all XENYX USB mixers.
Effective FX
Featuring the new 24-bit dual engine FX processor, with 16 editable, studio-grade presets including reverb, chorus, flanger, delay, pitch shifter and multi-effects. Complete with a highly accurate input meter, these effects can be altered to your personal taste via the Parameter control. Time-based functions can be entered manually by pressing the Tap button in tempo with the music.
Recording Bliss
There was a time when the recording process called for lots and lots of expensive gear, which meant the average musician had to buy time at a recording studio—and that time was pricey indeed. But modern technology has put personal recording well within the reach of virtually anyone with access to a computer. How do you get all that music flying around your brain into your computer? That's where XENYX USB mixers come in. Thanks to the built-in, bi-directional stereo USB audio interface, you can connect any of these mixers directly to your PC or Mac computer via a single USB cable. Now any signal source you connect to the mixer can be recorded directly to your hard drive. Which brings us to software…
Compose. Record. Mix. Share.
Tracktion puts the fun back into the creative process, so it's included free of charge with select Behringer products. This powerful, yet easy-to-use music production software is unlike anything you've seen before, putting everything you need on your desktop, on a single-screen, without the sea of drop down and hidden menus common to most other DAWs. In addition, Tracktion doesn't limit the number of tracks you can record, or the number of effects you can use. In fact, the only limitation is your Mac or PC computer's processing power. Recording and editing couldn't be easier; simply drag, drop, cut, copy or paste. Once your magnum opus is finished, share it with other "Tracktioneers" so they can listen, collaborate and edit. Visit Behringer.com to register your hardware, and you'll receive a redemption code to download Tracktion at no charge.
Value
No matter what your audio mixing needs are, Behringer USB Series mixers provide the performance and features that can take your talent to the next level, at a price that is sure to amaze you. Try one on today—we have one available in your size!
Specifications (Mic E.I.N.1 20 Hz - 20 kHz): • Frequency response: <10 Hz - 150 kHz (-1 dB), <10 Hz - 200 kHz (-3 dB) • Gain range: +10 dB to +60 dB • Max. input level: +12 dBu @ +10 dB gain • Impedance: 2.6 k ohms balanced • S/N ratio: 110 dB A-weighted (0 dBu In @ +22 dB gain) • Distortion (THD+N): 0.005%/0.004% A-weighted • Mono inputs: 4 mic inputs • AUX return: 3 dual 1/4" TRS connectors, balanced • Dimensions: 3-7/8" H x 16-1/6" W x 14-1/6" D (97 x 408 x 367 mm) • Weight: 10.6 lbs. (4.8 kg). Rack mount brackets included for standard 19" rack.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • Special FeaturesDigital Effects,USB Connectivity
  • XLR Mic Inputs6 to 8
  • BrandBehringer
  • ModelXENYX X2222USB
  • Part Number248-6608
  • UPC736211583345
  • Product CategoryMixers - Live Sound & Recording
    (1 Reviews)
  • Weight14.05 lbs.
View similar products to the Behringer XENYX X2222USB 22-Input 2/2-Bus Mixer w/ FX & USB
in the Mixers - Live Sound & Recording product category.
Behringer XENYX X2222USB 22-Input 2/2-Bus Mixer w/ FX & USB is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Great dependable and affordable mixer!This is a great mixer for smaller applications. Its veryuser friendly, affordable and is packed with a multipleof features. I recently installed this unit in a small country church, using an Alto amp with TOA HW-5"array" speakers and a Behringer EQ and wow..what a sound! (even in mono).It was very easy for my client to learn and produced a rich, balanced dynamic sound.I would highly recommend Behringer and this mixer!
Date published: 2012-05-08
  • 2016-02-06T07:09CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_248-6608, PRD, sort_mostRecent
