Behringer X32 32-Channel 16-Bus Digital Mixing Console
Brand:|Model: X32|Part # 248-6792
Behringer's X32 is intuitive and powerful with 40 processing channels and 25 mix buses, all equipped with serious signal processing (dynamics, EQ and inserts), which can be configured quickly to meet the demands of virtually any gig, large or small.
List Price$3,449.99
You Save33%
Belkin Digital IEEE-1394 6-Pin to 4-Pin FireWire Cable 6 ft.
Qty: 1Part # 189-035
List Price:$16.99
*Domestic US orders only
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
Behringer HPS3000 High Performance Studio Headphones
Qty: 1Part # 248-740
List Price:$29.99
Part # 248-6792
  • 32-channel total recall digital mixer with fully programmable high-end mic preamps and 16 mix buses, configurable as subgroups
  • Main LCR and all 16 mix buses feature inserts, 6-band parametric EQ, and dynamics processing
  • 16 analog XLR outputs plus 6 additional line in/outputs, 2 phones connectors and a talkback section with integrated or external mic
  • 48-channel digital snake ready* via AES50 ports featuring KLARK TEKNIK’s SuperMAC networking capability for ultra-low jitter and latency
  • Built-in XUF FireWire/USB audio interface card
  • Virtual FX rack featuring 8 true-stereo FX slots for simulations of famous outboard gear
The new Behringer X32 digital mixing console lets you focus on your event, instead of navigating a vast sea of knobs, buttons and menus like most other live digital mixers.
Ready for your input
Use any combination of the local 32 console mic inputs or the networked digital snake inputs on stage—their audiophile quality programmable preamps always ensure full control, purity and impeccable dynamics. The dedicated channel strip section puts 17 backlit buttons and 13 rotary controls with LED-collars right at your fingertips for nuanced adjustment of each channel's compressor, 4-band parametric EQ and much more. Each input and output channel strip features its own color backlit 128x64 graphic LCD, which provides vital channel information at-a-glance.
Virtual FX Rack
The onboard virtual FX Rack provides access to eight true-stereo, multi-effects processors (16 mono) including delay, chorus, dynamics—and it can run 4 production quality true-stereo reverbs concurrently with 8 channels of 31-band graphic equalization, all without the need for expensive, space-consuming external hardware.
High-count I/O options
I/O abounds with 32 high-end programmable mic preamps; 6 Aux inputs on 1/4" TRS; 16 balanced XLR Outs, plus balanced Control Room outputs on both XLR and 1/4" TRS connectors. A single CAT5 cable from FOH to the stage can receive up to 48 channels of audio input—and deliver all bus outputs, along with 16 individual monitor feeds for Behringer's brand new P16 personal monitoring system.
Vital information is just a click away
Thanks to the netbook-resolution, 800x480 high-contrast color TFT display, you are never more than one or two button presses away from any of X32's eight highly intuitive control screens. Once you select the desired function, dedicated rotary/push encoders allow you to set parameters and source I/O assignment, without the need to "drill down" through multiple layers of menus or page through a complex owner’s manual.
Versatile signal and scene management
Signals can be assigned to eight DCA groups (Digitally Controlled Amplifier), which provides simultaneous group level control via dedicated 100 mm motorized faders. The audio engineer can communicate with the talent by means of the Talkback section’s onboard mic or an external mic of their choosing. X32’s scene management allows snapshots of high-level production mixes to be captured and recalled for future use (you can even save them to a USB stick). X32 even has a dedicated custom control section with user-definable knobs and buttons where you can create your own set of controls, making it easy to access frequently used functions "on-the-fly."
Bus and rear panel flexibility
X32 provides extensive output connectivity including 16 balanced XLR outputs, six balanced Line I/O on 1/4" TRS connectors; dual Phones outputs; Main LCR (Left, Center, Right) buses; 16 mix buses (also configurable as subgroups) with Inserts, 6-band parametric EQ and dynamics processing; plus six independent Matrix Mixes with Inserts, also with 6-band parametric EQ and dynamics processing.
The rear panel also sports two AES50* ports, each with Klark Teknik's rock-solid SuperMAC 48-channel I/O networking capability (for addressing a total of 96 inputs and outputs). Stereo digital output and MIDI are also supported, as well as ultra-low jitter, ultra-low latency communication between the X32 and digital snakes, remote stage boxes and outboard recording devices. A convenient top panel USB port is available for recording an uncompressed two-channel "board mix" straight to any standard USB thumb drive or for playing background music.
The Future is Here—Now!
X32 ships with the insanely powerful XUF FireWire/USB audio interface card pre-installed in the expansion slot right out-of-the-box! XUF provides low latency 24-bit audio interfacing with Mac or PC host computers in the form of 32 In x 32 Out channels and MIDI. It even transmits HUI and Mackie Control data along with the audio I/O, which provides convenient remote control of your DAW via the X32 group fader section controls. XUF is compatible with CoreAudio on Mac OS 10.5 and above, and high-performance ASIO drivers for Windows PC are downloadable from
Compose. Record. Mix. Share.
Tracktion puts the fun back into the creative process, so it's included free of charge with select Behringer products. This powerful, yet easy-to-use music production software is unlike anything you've seen before, putting everything you need on your desktop, on a single-screen, without the sea of drop down and hidden menus common to most other DAWs. In addition, Tracktion doesn't limit the number of tracks you can record, or the number of effects you can use. In fact, the only limitation is your Mac or PC computer's processing power. Recording and editing couldn't be easier; simply drag, drop, cut, copy or paste. Once your magnum opus is finished, share it with other "Tracktioneers" so they can listen, collaborate and edit. Visit to register your hardware, and you'll receive a redemption code to download Tracktion at no charge.
Digital Mixing—Analog Price
The Behringer X32 digital mixing console sets a new benchmark for live sound mixing along with unprecedented value. Never before has any manufacturer offered a full-featured digital mixing console with such large input and output channel count, comprehensive processing, flexible expansion options and an intuitive user interface—all at a price point that has the competition shaking in their boots!
*FireWire, iPad, and iPhone are trademarks of Apple Inc., registered in the U.S. and other countries. The AES50 trademark is a property of the Audio Engineering Society, NY. All trademarks, including, but not limited to HUI, Mackie, Lexicon, PCM, EMT, Quantec and QRS are trademarks or registered trademarks of their respective owners. Their use neither constitutes a claim of the trademark nor affiliation of the trademark owners with MUSIC Group. Product names are mentioned solely as a reference for X32 compatibility and effects. **P16 Personal Monitoring System and Digital Snake are not included. * refers to all third-party trademarks, such as iPad, Lexicon etc. ** refers to items not included with X32, such as the P16 and Digital Snake.
  • Mixer TypeDigital
  • Special FeaturesDigital Effects,USB Connectivity
  • XLR Mic Inputs24 +
  • BrandBehringer
  • ModelX32
  • Part Number248-6792
  • UPC794504549614
  • Product CategoryMixers - Live Sound & Recording
    (2 Reviews)
  • Weight65 lbs.
View similar products to the Behringer X32 32-Channel 16-Bus Digital Mixing Console
in the Mixers - Live Sound & Recording product category.
