Behringer WD300 Warp Distortion Effects Pedal
Brand:|Model: WD300|Part # 248-6452
The WD300 effects pedal blows you away with dark energy, obscene distortion and endless sustain, turning your amp into a prowling beast.
  • Dual ultra-gain circuit that powers the most vicious and modern metal tone
  • Dedicated Gain, Warp, Level and Sub controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
The WARP DISTORTION WD300 propels your amp to a new level of fury, warping your favorite riffs into brutal, growling predators that show no mercy.
Nasty by Nature
Unlike well-behaved distortion pedals, the WD300 features a SUB control for boosting low end and a WARP control that adds an even nastier edge. Capable of generating tones from classic grit to modern metal, the WD300 provides gut-wrenching rhythm chops and leads that scream with virtually endless sustain. The blue status LED lets you know it's alive and snarling, while the first-class on/off switch provides superior signal integrity in bypass mode. You can feed this beast with our PSU-SB DC power supply (not included) or a 9V battery.
Value
Step on the WARP DISTORTION WD300 to enter an underworld of distortion that you'll never want to leave. From brazen to beastly, the affordable WD300 will redefine your tone and solidify your reign of terror.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelWD300
  • Part Number248-6452
  • UPC4033653052443
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.73 lbs.
View similar products to the Behringer WD300 Warp Distortion Effects Pedal
in the Guitar & Bass Effects Pedals product category.
