Behringer VS1220 Eurolive 600 Watt 12" 2-Way PA Speaker
Brand:|Model: VS1220|Part # 248-6764
Behringer's VS1220 is capable of handling input levels of 600 watts with its powerful 12" long excursion driver and wave-guide mounted electro-dynamic HF (High-Frequency) drivers.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
- Order Soon - Only 3 Left In Stock
List Price$179.99
You Save17%
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6764
  • High-performance 600 watt 2-way PA speaker system (150 watts Continuous/600 watts Peak Power)
  • Exceptional sound quality, wide frequency bandwidth and dynamic range
  • Extremely powerful 12" long-excursion driver provides incredibly deep bass and acoustic power
  • Proprietary dual electro-dynamic drivers for exceptional high-frequency reproduction
  • Elliptical wave guide design for ultra-wide sound dispersion
  • Integral tripod and stand adapter
Frequently Bought Together
The VS1220 loudspeaker provides exceptional sound quality at an extremely attractive price-point, is supremely portable and well suited for all sorts of sound reinforcement applications. Behringer designed the VS Series for budget-conscious musicians who demand high quality sound without the high price tag.
Exceptional Sound Quality
Capable of handling input levels up to 600 watts, the Eurolive VS1220 PA loudspeaker delivers exceptional sound quality. The powerful 12" long-excursion driver cranks out big tone in the bottom end and mid-range, while the wave-guide mounted electro-dynamic HF (High-Frequency) drivers output crisp and detailed highs. The VS1220's wide frequency bandwidth and extensive dynamic range make it ideal for a multitude of applications.
High-Impact Bass
In order to produce tight, deep bass, a loudspeaker has to move lots of air. Eurolive loudspeakers accomplish this by using powerful, long-excursion LF (Low Frequency) drivers that are handmade in our own factory. While some companies are content to use "off-the-shelf" drivers, we custom-design each LF driver to perfectly match each application. The VS1220 features an extremely powerful 12" long-excursion LF driver in a tuned enclosure, providing rich, tight bass all the way down to 60 Hz.
Crystal-Clear Highs
High-frequency content can easily make or break your performance. Too much and the sound becomes brittle and obnoxious, too little and it sounds muddy and poorly defined. VS1220's specially designed HF transducers, mounted in a proprietary elliptical wave-guide, deliver natural-sounding high end in an ultra-wide 80° x 40° sound dispersion pattern.
The VS1220 speaker has been optimized for maximum reliability through the integrated overload-protection circuitry, ensuring ultimate high-frequency driver protection. Designed to stand up to the rigors of the road, the VS1220 is built to look and sound great, even after years of rugged abuse!
VS1220's unique trapezoidal design makes it ideal for use in FOH (Front-of-House), as well as floor wedge and side fill monitor applications. Enclosures can be clustered, stacked, or even stand-mounted thanks to the built-in 35 mm (1.375") pole socket.
The Technical Stuff
The VS1220 is capable of extremely high sound pressure levels (93 dB full space 1 W @ 1 m) and provides a 60 Hz to 20 kHz frequency range. And at just under 38 lbs. (17.1 kg), the VS1220 is supremely portable. The internal crossover point is fixed at 3.5 kHz. Standard 1/4" TS connectors are provided.
Compare it to the competition. When you see and hear what the VS1220 offers in sound quality and features, you'll choose Behringer every time!
Specifications: • Continuous power: 150 watts • Peak power: 600 watts • Type: 2-way full range loudspeaker • Frequency response: 60 Hz - 20 kHz • Impedance: 8 ohms • SPL: 93 dB (Full space, 1W/1m) • Dispersion: 80° x 40° • Crossover frequency: 3.5 kHz • Rigging fittings: Ergonomically shaped handle, integral tripod/stand adapter • Components: HF driver - Dual electro dynamic drivers; LF driver - 12" (307 mm) • Dimensions: 23.6" H x 14.6" W x 16.9" D (600 x 370 x 430 mm) • Weight: 37.7 lbs. (17.7 kg).
  • Woofer Size12"
  • BrandBehringer
  • ModelVS1220
  • Part Number248-6764
  • UPC736211581945
  • Weight38.9 lbs.
View similar products to the Behringer VS1220 Eurolive 600 Watt 12" 2-Way PA Speaker
