Behringer VP2520 Eurolive 200 Watt Dual 15" 2-Way PA Speaker
Behringer VP2520 Eurolive 2000 Watt Dual 15" 2-Way PA Speaker
Brand:|Model: VP2520|Part # 248-6762
Behringer's VP2520 is capable of handling input levels of 2,000 watts with its powerful 15" long excursion driver and state-of-the-art 1.75" titanium diaphragm compression driver.
Part # 248-6762
  • Professional 2,000 watt 2 way PA speaker system (500 watts Continuous/2,000 watts Peak Power)
  • Exceptional sound quality, wide frequency bandwidth and dynamic range
  • 2 extremely powerful 15" long-excursion drivers provide incredibly deep bass and acoustic power
  • Proprietary 1.75" titanium-diaphragm compression driver for exceptional high-frequency reproduction
  • Proprietary horn design for ultra-wide sound dispersion
  • Overload-protection circuitry ensures optimal HF driver protection
Frequently Bought Together
Incredible sonic performance and amazing affordability merged into one, the VP2520 is the natural choice for commercial installation. The powerful dual 15" long-excursion drivers crank out big tone in the bottom end and mid-range, while the state-of-the-art 1.75" titanium-diaphragm compression driver delivers crisp and detailed highs. The VP2520's wide frequency bandwidth and extensive dynamic range make it ideal for a multitude of applications.
VP2520's unique trapezoidal design makes it ideal for use in FOH (Front-of-House), as well as floor wedge and side fill monitor applications. Enclosures can also be clustered atop the companion VP1800S subwoofer.
Big Bottom
In order to produce tight, deep bass, a loudspeaker has to move lots of air. Eurolive loudspeakers accomplish this by using powerful, long-excursion LF (Low Frequency) drivers that are handmade in our own factory. While some companies are content to use "off-the-shelf" drivers, we custom-design each LF driver to perfectly match each application. The VP2520 features two extremely powerful 15" long-excursion LF drivers in a tuned enclosure, providing massive, tight bass all the way down to 40 Hz.
Pristine Top End
High-frequency (HF) content can easily make or break your performance. Too much and the sound becomes brittle and obnoxious, too little and it sounds muddy and poorly defined. The state-of-the-art 1.75" titanium-diaphragm compression driver delivers natural-sounding high end, with an ultra-wide 80° x 50° sound dispersion pattern.
The Technical Stuff
The VP2520 is capable of extremely high sound pressure levels (96 dB full space 1 W @ 1 m) and provides a 40 Hz to 22 kHz frequency range. Weight is 87.7 lbs. (39.8 kg). The internal crossover point is fixed at 2.2 kHz. Both 1/4" and professional-style twist-lock connectors are provided.
Optimized for maximum reliability through the integrated overload-protection circuitry, the VP2520 ensures the ultimate high-frequency driver protection. Designed to stand up to the rigors of the road, the VP2520 is built to last and made to perform!
Compare it to the competition. When you see and hear what the VP2520 offers in sound quality and features, you'll own Behringer—with money to spare!
Specifications: • Continuous power: 500 watts • Peak power: 2,000 watts • Type: 2-1/2 way full range loudspeaker • Frequency response: 40 Hz - 22 kHz • Impedance: 4 ohms • SPL: 96 dB (Half space, 1W/1m) • Dispersion: 80° x 50° • Crossover frequency: 2.2 kHz • Rigging fittings: Ergonomically shaped handle • Components: HF driver - 1.75" titanium diaphragm compression driver; LF driver - 2 x 15" (385 mm) • Dimensions: 41.9" H x 18.7" W x 20.1" D (1,065 x 475 x 510 mm) • Weight: 87.7 lbs. (39.8 kg).
  • Woofer Size15"
  • BrandBehringer
  • ModelVP2520
  • Part Number248-6762
  • UPC4033653062282
  • Weight96 lbs.
View similar products to the Behringer VP2520 Eurolive 2000 Watt Dual 15" 2-Way PA Speaker
