BONUS ITEM INCLUDED
Behringer VP1520 Eurolive 1000 Watt 15" 2-Way PA Speaker
Brand:|Model: VP1520|Part # 248-6758
Behringer's VP1520 is capable of handling input levels of 1,000 watts with its powerful 15" long excursion driver and state-of-the-art 1.75" titanium diaphragm compression driver.
ORDER TODAY
Ships in 3-10 business days
List Price$269.99
You Save26%
$199.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6758
  • Professional 1,000 watt 2-way PA speaker system (250 watts continuous/1,000 watts peak power)
  • Exceptional sound quality, wide frequency bandwidth and dynamic range
  • Extremely powerful 15" long-excursion driver provides incredibly deep bass and acoustic power
  • Proprietary 1.75" titanium-diaphragm compression driver for exceptional high-frequency reproduction
  • Proprietary horn design for ultra-wide sound dispersion
  • Overload-protection circuitry ensures optimal HF driver protection
The VP1520 merges incredible versatility and sonic performance with amazing affordability, making it an ideal choice for musicians. The wide frequency bandwidth and extensive dynamic range of the VP1520 make it ideal for a multitude of applications.
In order to produce tight, deep bass, a loudspeaker has to move lots of air. EUROLIVE loudspeakers accomplish this by using powerful, long-excursion LF (Low Frequency) drivers that are handmade in our own factory. While some companies are content to use "off-the-shelf" drivers, we custom-design each LF driver to perfectly match each application. The VP1520 features an extremely powerful 15" long-excursion LF driver in a tuned enclosure, providing rich, tight bass all the way down to 50 Hz.
High-frequency (HF) content can easily make or break your performance. Too much and the sound becomes brittle and obnoxious, too little and it sounds muddy and poorly defined. The state-of-the-art 1.75" titanium-diaphragm compression driver delivers natural-sounding high end, with an ultra-wide 80° x 50° sound dispersion pattern.
The VP1520 is capable of extremely high sound pressure levels (94 dB full space 1 W/1m) and provides a 50 Hz to 22 kHz frequency range. And at just under 50 lbs (22.6 kg), the VP1520 is supremely portable. The internal crossover point is fixed at 2.5 kHz. Both 1/4" and professional-style twist-lock connectors are provided.
Optimized for maximum reliability through the integrated overload-protection circuitry, the VP1520 ensures the ultimate high-frequency driver protection. Designed to stand up to the rigors of the road, the VP1520 is built to last and made to perform!
VP1520's unique trapezoidal design makes it ideal for use in FOH (Front-of-House), as well as floor wedge and side fill monitor applications. Enclosures can be clustered, stacked, or even stand-mounted thanks to the built-in 35mm (1.375") pole socket.
Specifications: • Continuous power: 250 watts • Peak power: 1,000 watts • Frequency response: 50 Hz - 22 kHz • Impedance: 8 ohms • SPL: 94 dB • Dispersion: 80° x 50° • Crossover frequency: 2.5 kHz • Dimensions: 17.9" W x 27" H x 18.3" D (455 x 685 x 465 mm) • Weight: 49.8 lbs.
  • Woofer Size15"
  • BrandBehringer
  • ModelVP1520
  • Part Number248-6758
  • UPC736211581648
  • Weight57.6 lbs.
View similar products to the Behringer VP1520 Eurolive 1000 Watt 15" 2-Way PA Speaker
