Behringer VP1220F Eurolive 800 Watt 12" 2-Way Floor Monitor
Brand:|Model: VP1220F|Part # 248-6756
Behringer's VP1220F floor monitor is capable of handling input levels up to 800 watts with its powerful 12" long-excursion driver and 1.75" titanium-diaphragm compression driver.
Ships in 7-10 Business Days
List Price$224.99
You Save20%
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6756
  • Professional 800 watt 2-Way floor monitor (200 watts Continuous/800 watts Peak Power)
  • Exceptional sound quality, wide frequency bandwidth and dynamic range
  • Extremely powerful 12" long-excursion driver provides incredibly deep bass and acoustic power
  • Proprietary 1.75" titanium-diaphragm compression driver for exceptional high-frequency reproduction
  • Proprietary horn design for ultra-wide sound dispersion
  • Overload-protection circuitry ensures optimal HF driver protection
Frequently Bought Together
The Eurolvie VP1220F floor monitor delivers truly impressive sound quality, handling input levels up to 800 watts. The powerful 12" long-excursion driver cranks out big tone in the bottom end and mid-range, while the state-of-the-art 1.75" titanium-diaphragm compression driver delivers crisp and detailed highs. The VP1220F's wide frequency bandwidth and extensive dynamic range make it ideal for stage monitor applications.
Bass You Can Feel
In order to produce tight, deep bass, a loudspeaker has to move lots of air. Eurolive loudspeakers accomplish this by using powerful, long-excursion LF (Low Frequency) drivers that are handmade in our own factory. While some companies are content to use "off-the-shelf" drivers, we custom-design each LF driver to perfectly match each application. The VP1220F features an extremely powerful 12" long-excursion LF driver in a tuned enclosure, providing rich, tight bass all the way down to 55 Hz.
Top End that Cuts Through the Clutter
Good high-frequency (HF) performance is ultra-critical when it comes to stage monitors. Too much and the sound becomes brittle and obnoxious, too little and it sounds muddy and poorly defined. The state-of-the-art 1.75" titanium-diaphragm compression driver delivers natural-sounding high end, allowing you to hear your performance, even when the band is playing full out.
The Technical Stuff
The VP1220F is capable of extremely high sound pressure levels (93 dB full space 1 W @ 1 m) across an expansive 55 Hz to 22 kHz frequency range. And at just under 36 lbs. (16.2 kg), the VP1220F is supremely portable. The internal crossover point is fixed at 2.5 kHz. Both 1/4" and professional-style twist-lock connectors are provided.
Optimized for maximum reliability through the integrated overload-protection circuitry, the VP1220F monitor speaker ensures the ultimate high-frequency driver protection. Designed to stand up to the rigors of the road, the VP1220F is built to last and made to perform!
Specifications: • Continuous power: 200 watts • Peak power: 800 watts • Type: 2-way full-range loudspeaker • Frequency response: 55 Hz - 22 kHz • Impedance: 8 ohms • SPL: 93 dB (Full space, 1W/1m) • Dispersion: 80° x 50° • Crossover frequency: 2.5 kHz • Rigging fittings: Ergonomically shaped handle • Components: HF driver - 1.75" titanium diaphragm compression driver, LF driver - 12" (307 mm) • Dimensions: 16.9" H x 17.3" W x 22.6" D (430 x 440 x 575 mm) • Weight: 35.7 lbs. (16.2 kg).
  • ConfigurationStage Monitor
  • Woofer Size12"
  • BrandBehringer
  • ModelVP1220F
  • Part Number248-6756
  • UPC736211581549
  • Weight42.0000 lbs.
View similar products to the Behringer VP1220F Eurolive 800 Watt 12" 2-Way Floor Monitor
