Behringer VP1220 Eurolive 800 Watt 12" 2-Way PA Speaker
Brand:|Model: VP1220|Part # 248-6754
Behringer's VP1220 PA speaker is capable of handling input levels up to 800 watts with its powerful 12" long-excursion driver and 1.75" titanium-diaphragm compression driver.
Ships in 7-10 Business Days
List Price$239.99
You Save33%
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6754
  • Professional 800 watt 2 way PA speaker system (200 watts Continuous/800 watts Peak Power)
  • Exceptional sound quality, wide frequency bandwidth and dynamic range
  • Extremely powerful 12" long-excursion driver provides incredibly deep bass and acoustic power
  • Proprietary 1.75" titanium-diaphragm compression driver for exceptional high-frequency reproduction
  • Proprietary horn design for ultra-wide sound dispersion
  • Overload-protection circuitry ensures optimal HF driver protection
The Eurolive VP1220 PA loudspeaker delivers truly impressive sound quality, handling input levels up to 800 watts. The powerful 12" long-excursion driver cranks out big tone in the bottom end and mid-range, while the state-of-the-art 1.75" titanium-diaphragm compression driver delivers crisp and detailed highs. The VP1220's wide frequency bandwidth and extensive dynamic range make it ideal for a multitude of applications.
VP1220's unique trapezoidal design makes it ideal for use in FOH (Front-of-House), as well as floor wedge and side fill monitor applications. Enclosures can be clustered, stacked, or even stand-mounted thanks to the built-in 35 mm (1.375") pole socket.
Bass You Can Feel
In order to produce tight, deep bass, a loudspeaker has to move lots of air. EUROLIVE loudspeakers accomplish this by using powerful, long-excursion LF (Low Frequency) drivers that are handmade in our own factory. While some companies are content to use "off-the-shelf" drivers, we custom-design each LF driver to perfectly match each application. The VP1220 features an extremely powerful 12" long-excursion LF driver in a tuned enclosure, providing rich, tight bass all the way down to 55 Hz.
Pristine Top End
High-frequency (HF) content can easily make or break your performance. Too much and the sound becomes brittle and obnoxious, too little and it sounds muddy and poorly defined. The state-of-the-art 1.75" titanium-diaphragm compression driver delivers natural-sounding high end, with an ultra-wide 80° x 50° sound dispersion pattern.
The Technical Stuff
The VP1220 is capable of extremely high sound pressure levels (93 dB full space 1 W @ 1 m) and provides a 55 Hz to 22 kHz frequency range. And at just under 40 lbs (17.9 kg), the VP1220 is supremely portable. The internal crossover point is fixed at 2.5 kHz. Both 1/4" and professional-style twist-lock connectors are provided.
Optimized for maximum reliability through the integrated overload-protection circuitry, the VP1220 ensures the ultimate high-frequency driver protection. Designed to stand up to the rigors of the road, the VP1220 is built to last and made to perform!
Specifications: • Continuous power: 200 watts • Peak power: 800 watts • Type: 2-way full-range loudspeaker • Frequency response: 55 Hz - 22 kHz • Impedance: 8 ohms • SPL: 93 dB (Full space, 1W/1m) • Dispersion: 80° x 50° • Crossover frequency: 2.5 kHz • Rigging fittings: Ergonomically shaped handle, integral tripod, stand adapter • Components: HF driver - 1.75" titanium diaphragm compression driver, LF driver - 12" (307 mm) • Dimensions: 23.6" H x 14.6" W x 16.9" D (600 x 370 x 430 mm) • Weight: 39.5 lbs. (17.9 kg).
  • Woofer Size12"
  • BrandBehringer
  • ModelVP1220
  • Part Number248-6754
  • UPC705105732336
  • Weight45 lbs.
View similar products to the Behringer VP1220 Eurolive 800 Watt 12" 2-Way PA Speaker
