Behringer UZ400 Classic Fuzz Distortion Effects Pedal
Brand:|Model: UZ400|Part # 248-6430
The UZ400 effects pedal by Behringer re-creates the classic and burning fuzz tone used by so many legendary guitarists of the '60s and '70s.
Comparable Items In Stock:
Part # 248-6430
  • Recreate the classic and burning fuzz tone of the '60s and '70s
  • Dedicated Fuzz, Tone, and Level controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
Turn on to the pure rock satisfaction that lies within the ULTRA FUZZ UZ400—then hold tight as it morphs your amp into a volcanic weapon of mass distortion.
Corduroy Bell-Bottoms (Audio C)
More than just a simple blast from the past, the Ultra Fuzz churns out supercharged vintage grit, giving your riffs buzz-saw power and sustaining your leads into the '70s—the 2070s, that is!
Easy to Dial-in
Twist the dedicated FUZZ, TONE and LEVEL dials to create a sound that's every bit as dirty as you want it to be. The blue LED tells you when it's activated and the on/off switch maintains outstanding signal integrity in bypass mode. You can power this box o' dirt with a 9V battery or our PSU-SB DC power supply (not included).
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelUZ400
  • Part Number248-6430
  • UPC4033653052702
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.73 lbs.
View similar products to the Behringer UZ400 Classic Fuzz Distortion Effects Pedal
in the Guitar & Bass Effects Pedals product category.
