Behringer UW300 Ultimate Auto-Wah Effects Pedal
Brand:|Model: UW300|Part # 248-6428
The UW300 gives you popular auto-wah effects for all styles and sounds as well as killer performance that'll make your blood freeze.
  • Killer wah pedal—offers auto-wah effects for all styles and sounds
  • Dedicated Sensitivity, Manual, Depth and Rate controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
For the ultimate in auto-wah tone, step on the ULTRA WAH UW300 and let your guitar speak for itself. One toe-tap and you'll hear "Wah, wah, wah!" all the way home.
User-Friendly Auto-Wah
The UW300 provides an immense array of wah tones thanks to its dedicated SENSITIVITY, DEPTH, RATE and MANUAL controls. The Manual dial gives you the power to specify the frequency where the effect starts working. For example, high Manual settings decrease the sweep range because the low end of the frequency sweep is moved upwards. The Sensitivity control provides control over when the auto-wah is activated, and is totally dependent on how hard you play. So, whether you've dialed in a traditional wah-wah whine or a thick psychedelic haze, the UW300 responds instantly to your performance dynamics.
The Power to Wah
The UW300’s bright blue LED tells you when it's activated (it can also be used for a UFO landing beacon), and the excellent electronic on/off switch maintains pristine signal integrity in bypass mode. You can power the UW300 with a 9V battery or our PSU-SB DC power supply (not included).
Value
For an arsenal of auto-wah sounds made easy and affordable, take the ULTRA WAH UW300 on a trip down "Psychedelic Lane."
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelUW300
  • Part Number248-6428
  • UPC4033653052504
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.9 lbs.
View similar products to the Behringer UW300 Ultimate Auto-Wah Effects Pedal
in the Guitar & Bass Effects Pedals product category.
