Behringer UV300 Classic Vibrato Effects Pedal
Brand:|Model: UV300|Part # 248-6426
The UV300 effects pedal takes you on a psychedelic music voyage with classic and mind-bending vibrato effects from the '60s and '70s.
List Price$37.99
You Save34%
$24.99
Part # 248-6426
  • Experience classic and mind-bending, dimensional vibrato effects of the '60s and '70s
  • Dedicated Depth, Rate, Rise and Mode controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
Kicking the ULTRA VIBRATO UV300 into action is like putting an invisible, automatic whammy bar on your guitar. From the gentle, pulsing rhythms of the ocean surf, to the wild, whirling effects of a rotating speaker system, the UV300 will bring a dose of days-gone-by to your sound.
Altered State
Select from UNLATCH, BYPASS or LATCH modes, then twist the dedicated RISE, RATE and DEPTH dials. In Latch mode, the effect is constantly on once you step on it. Unlatch mode only applies the effect while you press down on the pedal, so you can add vibrato to a single not if you like. You're guitar will be playing mind-games with everyone in earshot as familiar, but hardly ordinary, tones of the 1960s and '70s ooze out of your amp.
Power Options
The blue LED tells you when the UV300 is activated, and the first-class on/off switch maintains peerless signal integrity in bypass mode. You can power Behringer stomps with a 9V battery or our PSU-SB DC power supply (not included).
Value
To every tone, there is a time and purpose for getting...well, a little "retro-spective." When that mood strikes, you'll be glad you brought along your trusty ULTRA VIBRATO UV300.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelUV300
  • Part Number248-6426
  • UPC689076115711
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.73 lbs.
View similar products to the Behringer UV300 Classic Vibrato Effects Pedal
in the Guitar & Bass Effects Pedals product category.
