Behringer UT300 Classic Tremolo Effects Pedal
Brand:|Model: UT300|Part # 248-6752
The UT300 is specifically designed to provide guitarists easy-to-use tremolo effect styles. With its high-performance features you get classic, warm, and mind-bending tremolo effects of the vintage '60s amps.
ORDER TODAY
Ships in 7-10 Business Days
List Price$37.99
You Save34%
$24.99
Part # 248-6752
  • Get the classic, warm and mind-bending tremolo effects of vintage ‘60s amps
  • Dedicated Rate, Wave and Depth controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
The classic surf music of the '50s and '60s might not have even happened if tremolo hadn’t come along. Vintage amps produced this intriguing effect by pulsing the volume of the instrument signal at a user-adjustable rate. The UT300 pays homage to this legendary sound, bringing it up to date for modern surf freaks.
With its dedicated Rate, Wave and Depth dials, you can shape a pulsating tremolo that nails every sound from rowdy rockabilly and surging surf to modern space-rock. A red LED tells you when the effect is activated, and you can power this groovy stomp box with either a PSU-SB DC power supply (not included) or a 9V battery. A top-quality On/Off switch maintains excellent signal integrity in bypass mode.
Specifications: • Input & output connectors: 1/4" TS • Input impedance: 500k ohm • Output impedance: 1k ohm • Power supply: 9 VDC, 100 mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 &3149; Power consumption: 30 mA • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelUT300
  • Part Number248-6752
  • UPC736211844675
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.73 lbs.
View similar products to the Behringer UT300 Classic Tremolo Effects Pedal
in the Guitar & Bass Effects Pedals product category.
