Behringer US600 Ultimate Pitch Shifter/Hamonist Effect Pedal
Brand:|Model: US600|Part # 248-6750
Shift single notes and chords and even create intelligent harmonies to your notes with Behringer's US600 effect pedal. Use the Tremolor Arm/Flutter effect to bend single notes or simulate the movement of the tremolo bar.
List Price$74.99
You Save33%
Part # 248-6750
  • The ultimate Pitch Shifter/Harmonist to shift single notes and chords or even create intelligent harmonies to your notes—at the touch of a footswitch
  • Real Sound Modeling (RSM) combines state-of-the-art DSP technology with sophisticated algorithms to emulate real acoustic environments
  • Take off with incredible Tremolo Arm/Flutter effects to bend single notes up to +/-2 octaves or simulate the movement of the tremolo bar
  • Dedicated Mode, Pitch, HR Key, Delay time/speed and Balance controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
Tremolo bars add a handsome shimmer to your guitar sound by detuning your strings and then returning them to pitch. And the sound of two guitars playing in harmony adds a soaring, heroic touch to an ordinary lead. The US600 is built to take the place of a tremolo bar AND a second guitarist. Its Real Sound Modeling (RSM) technology produces sophisticated algorithms that deliver the delicate harmonic overtones that are critical to creating realistic harmonies and transpositions.
The US600 stomp box offers 5 totally different-sounding Modes: Tremolo Bar, Flutter, Detune, Harmonist and Pitch Shifter. Pitch Shift and Tremolo Bar pitch can be shifted from 0 to 2 octaves; Harmonist pitch can be tweaked to track 3rds, 4ths, 5ths, 6ths, octaves or double octaves. There's a separate 10-step Key select control as well as Delay/Speed control and Balance to dial in how much effect you want to mix with a dry signal. A brilliant blue LED indicates power status and battery condition. The footswitch is ultra-strong to last through years of gigging. And in bypass mode, it preserves signal integrity by taking all pedal circuitry out of your chain. The US600 pedal is designed to give you the utmost flexibility, running on our BEHRINGER PSU-SB DC power supply or a typical 9V battery.
Plug into the US600 and take your guitar places it has never been. Now even a solitary guitarist whose axe sports a steadfast bridge can harness the power of harmony and tremolo!
Specifications: • Input & output A/B connectors: 1/4" TS • Input impedance: 500k ohm • Output A/B impedance: 1k ohm • Power supply: 9 VDC, 100 mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 &3149; Power consumption: 30 mA • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelUS600
  • Part Number248-6750
  • UPC689076114912
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.88 lbs.
View similar products to the Behringer US600 Ultimate Pitch Shifter/Hamonist Effect Pedal
in the Guitar & Bass Effects Pedals product category.
