Behringer UP300 2-Mode Phaser Effects Pedal
Brand:|Model: UP300|Part # 248-6748
Designed for all musicians wanting to pep up their sound, the UP300 allows you to crate phase shifting effects modeled after two of the most legendary pedals.
  • Get 2 phasers in one—sound modeled after 2 of the most legendary pedals
  • Dedicated Level, Rate, Depth and Resonance controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
Frequently Bought Together
With two distinctly different phase shifters built into one incredibly twisted pedal, the UP300 grants access to every conceivable shade of sonic dementia. In Mode I with the dedicated Rate and Depth dials set high, you get a warped, warbling phase shift that turns your guitar into a symphony of lysergic rubber bands. If a more traditional sound suits your mood, slip into Mode II and enjoy the blissed-out shimmer of classic rock's trippiest moments. Whether you're looking for a sweet lunar breeze or the roar of an interplanetary ocean to push your tone beyond your normal confines, the Ultra Phase Shifter UP300 is ready to help you make a change for the strange.
Control the overall parameters of the effect with the dedicated Level and RES(onance) dials. The status LED lets you know when the UP300's lucid magic is working, and a top-quality on/off switch maintains pristine signal integrity in bypass mode. Power it with either our PSU-SB DC power supply (not included) or a 9V battery.
Specifications: • Input & output connectors: 1/4" TS • Input impedance: 500k ohm • Output impedance: 1k ohm • Power supply: 9 VDC, 100 mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 &3149; Power consumption: 30 mA • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelUP300
  • Part Number248-6748
  • UPC4033653052139
  • Product CategoryGuitar & Bass Effects Pedals
    (1 Reviews)
  • Weight0.73 lbs.
View similar products to the Behringer UP300 2-Mode Phaser Effects Pedal
in the Guitar & Bass Effects Pedals product category.
