Behringer UMX610 61-Key USB / MIDI Controller Board
Brand:|Model: UMX610|Part # 248-6580
The control is right at your fingertips with Behringer's UMX610 61-key MIDI controller board, with 22 assignable controllers and over 100 virtual instruments and 50 effects.
List Price$269.99
You Save33%
$179.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6580
  • 100 virtual instruments and 50 VST effects plus an unlimited number of sound creations
  • Velocity-sensitive USB/MIDI keyboard featuring 61 high-quality full-size keys
  • USB/Audio interface included for recording and playback of any digital music file
  • Free download of Tracktion music production software
  • Intuitive sound module NI KorePlayer with production-ready 300 MB sound library
  • Plug and play with Mac OS X, Windows XP and Vista operating systems
  • 8 real-time rotary controls plus 10 assignable switches
Frequently Bought Together
The UMX610 61-key MIDI Controller is an extremely flexible master keyboard with a control section for a wide range of applications. Do you need independent control of hardware synthesizers or general MIDI sound modules? How about control over effects devices? Maybe you just want to operate sequencing software or computer plug-ins from a convenient remote location? UMX Series controllers provide total flexibility and tremendous ease of use, allowing you to realize your ideas intuitively.
What is a MIDI Controller?
Simply put, a MIDI controller gives you the power to take command of any hardware device or software that understands MIDI (Musical Instrument Digital Interface). This means that MIDI addressable effects processors (such as delays, reverbs, etc.) and audio recording and editing software can be controlled with a single piece of hardware, a MIDI controller. This can be very handy indeed when you have lots of devices spread The UMX MIDI Controller is an extremely flexible master keyboard with a control section for a wide range of applications. Do you need independent control of hardware synthesizers or general MIDI sound modules? How about control over effects devices? Maybe you just want to operate sequencing software or computer plug-ins from a convenient remote location? UMX Series controllers provide total flexibility and tremendous ease of use, allowing you to realize your ideas intuitively.
When it comes to remote control, you get 8 knobs, 10 assignable switches, 2 wheels (Pitch Bend & Modulation), 1 pedal port and 1 fader, for a total of 22 assignable controllers — which means total control of your operating environment. Once you've assigned the parameters for a particular scenario, simply store it in your user preset.
More Than Just MIDI
As an added bonus, we’ve included our UCA222 USB Audio Interface to access your PC or Mac computer’s audio capability. You can use the UCA222 to connect sound modules directly to any free computer USB port and listen to either the input or output signal via headphones or through active studio monitors. The UCA222 also features an additional S/PDIF optical output for direct digital conversion and is completely powered via USB—no external power supply needed. With its dual analog mono inputs, any line-level device, such as a mixer or tape deck, can be connected hassle-free to your computer.
Unleash Your Creativity With More Than 100 Instruments and Effects Plug-Ins
Behringer has included over 100 virtual instruments plus more than 50 effects plug-ins to get you rockin' right out of the box! Jam with a virtual e-piano or take off with breathtaking synthesizer sounds. Tweak your sounds with creative tube amps and multi-FX plus high-end studio reverbs, equalizers, compressors, choruses and many more.
Compose. Record. Mix. Share.
Tracktion puts the fun back into the creative process, so it's included free of charge with select Behringer products. This powerful, yet easy-to-use music production software is unlike anything you've seen before, putting everything you need on your desktop, on a single-screen, without the sea of drop down and hidden menus common to most other DAWs. In addition, Tracktion doesn't limit the number of tracks you can record, or the number of effects you can use. In fact, the only limitation is your Mac or PC computer's processing power. Recording and editing couldn't be easier; simply drag, drop, cut, copy or paste. Once your magnum opus is finished, share it with other "Tracktioneers" so they can listen, collaborate and edit. Visit Behringer.com to register your hardware, and you'll receive a redemption code to download Tracktion at no charge.
energyXT2.5 Compact BEHRINGER Edition
Behringer's also included XT Software’s energyXT2.5 Compact Behinger Edition so you can take your recording projects to the next level. This amazing DAW (Digital Audio Workstation) makes it easy to manipulate your audio and MIDI files, turning song ideas into stunning CD or web-ready recordings. And it works in all platforms, including Windows XP, Vista, Mac OSX and Linux. energyXT2.5 includes its own multi-FX processor, built-in synthesizers and a drum machine, both of which can be accessed directly.
Power supply options
Because they need to be ready for action in a variety of venues, UMX Series controllers can draw operating power from any free USB port on your PC or Mac computer, 3 AA batteries or the optional external power supply.
Specifications: • Keyboard: 61 keys, velocity-sensitive • Switch Plug: Foot pedal 1/4" mono jack with automatic polarity recognition • Battery: 3 x 1.5V (type "AA") • Power consumption: 0.9 watt max • Dimensions: Approx. 8-15/32" W x 3-26/32" H x 38-31/32" D (215 x 97 x 990 mm) • Weight: Approx. 10-11/32 lbs. (4.69 kg).
  • BrandBehringer
  • ModelUMX610
  • Part Number248-6580
  • UPC705105161082
  • Product CategoryMIDI Controllers
    (1 Reviews)
  • Weight10.34 lbs.
View similar products to the Behringer UMX610 61-Key USB / MIDI Controller Board
in the MIDI Controllers product category.
