Behringer UMX250 25-Key USB / MIDI Controller Board
Brand:|Model: UMX250|Part # 248-6576
The control is right at your fingertips with Behringer's UMX250 25-key MIDI controller board, with 22 assignable controllers and over 100 virtual instruments and 50 effects.
List Price$149.99
You Save33%
$99.99
Part # 248-6576
  • Unleash your creativity with 100 virtual instruments and take off with 50 VST effects
  • Velocity-sensitive USB/MIDI keyboard featuring 25 high-quality full-size keys
  • USB/Audio interface included for recording and playback of any digital music file
  • Free download of Tracktion music production software
  • Intuitive sound module NI KorePlayer with production-ready 300 MB sound library
  • Plug and play with Mac OS X, Windows XP and Vista operating systems
  • 8 real-time rotary controls plus 10 assignable switches
The UMX250 25-key MIDI Controller is an extremely flexible master keyboard with a control section for a wide range of applications. Do you need independent control of hardware synthesizers or general MIDI sound modules? How about control over effects devices? Maybe you just want to operate sequencing software or computer plug-ins from a convenient remote location? UMX Series controllers provide total flexibility and tremendous ease of use, allowing you to realize your ideas intuitively.
What is a MIDI Controller?
Simply put, a MIDI controller gives you the power to take command of any hardware device or software that understands MIDI (Musical Instrument Digital Interface). This means that MIDI addressable effects processors (such as delays, reverbs, etc.) and audio recording and editing software can be controlled with a single piece of hardware, a MIDI controller. This can be very handy indeed when you have lots of devices spread The UMX MIDI Controller is an extremely flexible master keyboard with a control section for a wide range of applications. Do you need independent control of hardware synthesizers or general MIDI sound modules? How about control over effects devices? Maybe you just want to operate sequencing software or computer plug-ins from a convenient remote location? UMX Series controllers provide total flexibility and tremendous ease of use, allowing you to realize your ideas intuitively.
When it comes to remote control, you get 8 knobs, 10 assignable switches, 2 wheels (Pitch Bend & Modulation), 1 pedal port and 1 fader, for a total of 22 assignable controllers — which means total control of your operating environment. Once you’ve assigned the parameters for a particular scenario, simply store it in your user preset. All UMX Series controllers feature our custom-designed key-bed, which has been praised by some of the industry’s top product reviewers and players alike for its responsiveness and playability
More Than Just MIDI
As an added bonus, we’ve included our UCA222 USB Audio Interface to access your PC or Mac computer’s audio capability. You can use the UCA222 to connect sound modules directly to any free computer USB port and listen to either the input or output signal via headphones or through active studio monitors. The UCA222 also features an additional S/PDIF optical output for direct digital conversion and is completely powered via USB—no external power supply needed. With its dual analog mono inputs, any line-level device, such as a mixer or tape deck, can be connected hassle-free to your computer.
Here are a just few reasons you need a UMX controller
• For playing external sound modules, rack synthesizers and virtual instruments
• For editing sound parameters of synthesizers, sound samplers and GM/GS/XG sound generators
• Controlling parameters on outboard equipment and software plug-ins, such as effects processors, compressors and digital equalizers
• Remotely controlling software mixers (functions for volume, pan, mute, etc.)
• Live control of volume and sound parameters of sound modules on stage
Unleash Your Creativity With More Than 100 Instruments and Effects Plug-Ins
Behringer's included over 100 virtual instruments plus more than 50 effects plug-ins to get you rockin’ right out of the box! Jam with a virtual e-piano or take off with breathtaking synthesizer sounds. Tweak your sounds with creative tube amps and multi-FX plus high-end studio reverbs, equalizers, compressors, choruses and many more.
Compose. Record. Mix. Share.
Tracktion puts the fun back into the creative process, so it's included free of charge with select Behringer products. This powerful, yet easy-to-use music production software is unlike anything you've seen before, putting everything you need on your desktop, on a single-screen, without the sea of drop down and hidden menus common to most other DAWs. In addition, Tracktion doesn't limit the number of tracks you can record, or the number of effects you can use. In fact, the only limitation is your Mac or PC computer's processing power. Recording and editing couldn't be easier; simply drag, drop, cut, copy or paste. Once your magnum opus is finished, share it with other "Tracktioneers" so they can listen, collaborate and edit. Visit Behringer.com to register your hardware, and you'll receive a redemption code to download Tracktion at no charge.
Power supply options
Because they need to be ready for action in a variety of venues, UMX Series controllers can draw operating power from any free USB port on your PC or Mac computer, 3 AA batteries or the optional external power supply.
Specifications: • Keyboard: 25 keys, velocity-sensitive • Switch plug: Foot pedal 1/4" mono jack with automatic polarity recognition • Battery: 3 x 1.5V mignon (type "AA") • Power consumption: max 0.9 watts • Dimensions: approx. 8-15/32" H x 3-26/32" W x 19-15/32" D (215 x 97 x 495 mm).
  • BrandBehringer
  • ModelUMX250
  • Part Number248-6576
  • UPC705105160887
  • Product CategoryMIDI Controllers
  • Weight7.85 lbs.
View similar products to the Behringer UMX250 25-Key USB / MIDI Controller Board
in the MIDI Controllers product category.
