Behringer UM300 Heavy Metal Distortion Effects Pedal
Brand:|Model: UM300|Part # 248-6412
Produce super thick, tube-like distortion plus endless sustain with the dual-gain circuitry of Behringer's UM300 effect pedal.
List Price$37.99
You Save34%
$24.99
Part # 248-6412
  • Take off with the most extreme and sought-after hard rock or heavy metal distortion
  • Multi-gain circuitry to give you super-thick, tube-like distortion plus endless sustain
  • Dedicated Distortion, 3-band EQ and Level controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
In the churning, smoldering world of heavy metal, it’s the middle frequencies that make the difference between mush and muscle.  With the UM300 ULTRA METAL, you not only get take control of the Mids, you micromanage them!
Metal to the Max
The UM300 effects pedal gives you the most extreme, sought-after hard rock and heavy metal sounds with super-thick, tube-like distortion—plus virtually endless sustain.
The Art of Tone
Like most distortion stomp boxes, the UM300 comes with DISTORTION and LEVEL controls. And the HIGH and LOW controls let you dial in the amount of top-end and bottom you desire. But the similarity to other stomps ends right there. Much like our world-class mixing consoles, we've given the UM300 a MID FREQ control, allowing you to select a midrange frequency (from 200 Hz to 5 kHz) and boost/cut it by up to 15 dB (that's a lot!). What this means, in terms of tone, is thick, tube-like distortion with endless sustain, for everything from aggressive, traditional metal assaults to bone-crunching mayhem.
A bright blue LED tells you when the UM300 is active, while a top-quality on/off switch maintains highest signal integrity in bypass mode. You can power the UM300 with our PSU-SB DC power supply (not included), or pop in a 9V battery.
Massive in the Middle
Is there a hole in the middle of your tone? You’ll be surprised how affordably and efficiently the ULTRA METAL UM300 can fill that void.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelUM300
  • Part Number248-6412
  • UPC689076752572
  • Product CategoryGuitar & Bass Effects Pedals
    (1 Reviews)
  • Weight0.73 lbs.
View similar products to the Behringer UM300 Heavy Metal Distortion Effects Pedal
in the Guitar & Bass Effects Pedals product category.
