Behringer Ultragain ADA8200 8 In/8 Out ADAT Digital Audio Interface / Mic Preamp
Brand:|Model: ADA8200|Part # 248-6840
The Behringer Ultragain ADA8200 is the professional’s edge for converting multi-track signals from digital to analog, or vice versa. The ADA8200 is sublimely easy to operate, fits neatly into a single rack space, and thanks to its Midas-designed mic preamps and integrated A/D and D/A converters you’ll get optimal signal conversion, without the slightest hint of distortion or signal deterioration!
List Price$299.99
You Save33%
$199.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6840
  • Ultra-high quality 8-channel A/D and D/A interface
  • 8 state-of-the-art Midas-designed mic preamplifiers
  • Reference-class Cirrus Logic 24-bit converters for ultimate signal integrity
  • 3-year warranty
The Ultragain ADA8200 builds on the proud legacy of Behringer's ADA8000, which is one of their all-time best-selling products. Now, you’re probably thinking, "If they sell so many ADA8000s, then why are they changing them?" The short answer: they improved it, by upgrading to reference-class Cirrus Logic converters and Midas-designed mic preamps, making the ADA8200 the natural choice for musicians, audio engineers, and audiophiles alike.
The Technical Stuff
Signal conversion in the ADA8200 takes place at either 44.1 or 48 kHz with 24-bit resolution. The ADAT inputs and outputs can be operated independently, as long as there is an identical wordclock signal. Frequency range is an ultra-wide 10 Hz - 24 kHz at a 48 kHz sampling rate.
The Ins and Outs
Connections are provided for balanced XLR and 1/4" TRS, as well as unbalanced 1/4" TS inputs. XLR line out connectors located on the rear panel provide either balanced or unbalanced connectivity. Digital I/O is handled via ADAT format TOSLINK optical sockets, which support up to 8 channels of data.
Behringer Value
If you're already a Behringer user, we don't need to explain the tremendous value offered by Behringer products. If you've never tried Behringer, now is the time. Odds are you've been spending more than you should on "boutique" brands, or wasting money on under-performing "budget" gear. You can trust all your digital ones and zeros to the ADA8200, at an ultra-affordable price that will amaze you. Grab one today and expand your digital arsenal.
Important Compatibility Information
There is a known issue with the ADAT interface implementation of the MOTU 2408 audio interface that makes it incompatible with the ADA8000/ADA8200 under certain operating conditions. Users are advised to avoid the following configuration:
  • The MOTU 2408 is connected to a MOTU PCI-424 card and operating in PCI Mode under computer control
  • The ADA8000/ADA8200 SYNC option is set to SLAVE and the clock input is being supplied from the MOTU 2408
  • The optical output from the ADA8000 ADAT interface is connected to an ADAT input on the MOTU 2408
  • BrandBehringer
  • ModelADA8200
  • Part Number248-6840
  • UPC713757157612
  • Product CategoryMicrophone Preamps & Channel Strips
    (1 Reviews)
  • Weight4.0000 lbs.
View similar products to the Behringer Ultragain ADA8200 8 In/8 Out ADAT Digital Audio Interface / Mic Preamp
in the Microphone Preamps & Channel Strips product category.
