Behringer UFO202 USB/Audio Interface with Phono Preamp
Brand:|Model: UFO202|Part # 248-6506
You will now be able to transfer all your great albums from the vinyl and tape eras into the digital realm with the help of Behringer's UFO202.
- Order Soon - Only 3 Left In Stock
List Price$44.99
You Save33%
$29.99
Part # 248-6506
  • High-quality USB audio interface connects your turntable, cassette player, etc. with your computer
  • Transfer and restore your valuable vinyl records and tapes to your computer w/simple USB connection
  • Free download of Tracktion music production software
  • Phono input switchable to line input source
  • Stereo output allows easy connection & playback of computer audio files over your home sound system
  • High-resolution 48 kHz converters for high-end audio quality
  • Stereo Headphone output with dedicated Level control lets you monitor your input source
Love Your Old Records and Cassette Tapes?
We love ours too! That’s why we built the UFO202 — a simple, affordable way to get your records and vinyl tapes into the digital realm. The UFO202 is easy to use and comes with professional software that not only converts your favorite recordings into files on your computer, but also removes those annoying scratches and pops so common to vinyl media. State of- the-art, switchable Line/Phono preamps and digital converters ensure the utmost in sound quality, making the U-PHONO UFO202 Audio Interface a must-have for every audiophile.
PC and Mac Ready
This ultra-compact, USB-powered device lets you connect your PC or Mac computer to virtually any piece of audio gear. It gets its power from your computer's USB bus, so no external power supply or batteries are required. And the UFO202 requires no special setup or drivers—just plug it in to a free USB port and start recording.
Extreme Versatility
The UFO202 features a stereo input for connecting turntables or any line-level device (such as a mixer or tape deck), plus a stereo analog output for connecting active speakers or studio monitors. You can also connect electronic keyboards, sound modules, drum machines and line-level devices (such as the V-AMP 3) directly to your computer for recording. The Volume control allows you to set the level of the stereo headphones.
Powerful Recording Interface
When used as a professional interface between a mixing console and your computer, myriad options become available. Some of these might include connecting the UFO202's RCA outputs to the TAPE INPUT jacks of your mixer or active monitors, or directly into the input channels of the mixer. Connecting to mixer input channels gives you access to equalization and allows the use of the AUX Send features of your mixer to build extremely versatile monitor mixes for your recording sessions.
Compose. Record. Mix. Share.
Tracktion puts the fun back into the creative process, so it's included free of charge with select Behringer products. This powerful, yet easy-to-use music production software is unlike anything you've seen before, putting everything you need on your desktop, on a single-screen, without the sea of drop down and hidden menus common to most other DAWs. In addition, Tracktion doesn't limit the number of tracks you can record, or the number of effects you can use. In fact, the only limitation is your Mac or PC computer's processing power. Recording and editing couldn't be easier; simply drag, drop, cut, copy or paste. Once your magnum opus is finished, share it with other "Tracktioneers" so they can listen, collaborate and edit. Visit Behringer.com to register your hardware, and you'll receive a redemption code to download Tracktion at no charge.
Value
Now for just a fraction of the price you'd pay for a USB turntable you can have state-of-the-art digital conversion, world-class recording and editing software, and hassle-free connectivity between your PC or Mac computer and virtually any piece of audio gear, including phono turntables and tape decks. Bridging the gap between your music and the rest of the world—the Behringer U-PHONO UFO202.
Specifications: • Frequency response: 10 Hz - 20 kHz, ±1 dB @ 44.1 kHz sample rate; 10 Hz - 22 kHz, ±1 dB @ 48 kHz sample rate • THD: 0.05% typ. @ -10 dBV, 1 kHz • Crosstalk: -77 dB @ 0 dBV, 1 kHz • S/N ratio: A/D 89 dB typ. @ 1 kHz, a-weighted; D/A 96 dB typ. @ 1 kHz, a-weighted • Dimensions: Approx. 0.87" H x 3.46" W x 2.36" D • Weight: Approx. 0.26 lbs.
  • BrandBehringer
  • ModelUFO202
  • Part Number248-6506
  • UPC705105731834
  • Product CategoryComputer Accessories
    (12 Reviews)
  • Weight0.65 lbs.
View similar products to the Behringer UFO202 USB/Audio Interface with Phono Preamp
in the Computer Accessories product category.
Behringer UFO202 USB/Audio Interface with Phono Preamp is rated 4.5833 out of 5 by 12.
Rated 4 out of 5 by from Does the jobI'm using an Apple computer and found that it works with GarageBand right out of the box. I don't know why this is not mentioned anywhere. As recommended, I downloaded Audacity but then found that I needed Lame-Lib or some such to get the UFO to talk to my computer. Was unable to successfully complete this extra, extra step so decided to try GarageBand and it worked like a charm.
Date published: 2015-03-17
Rated 5 out of 5 by from Great Phono Pre-Amp with a digitizer included!This is a great sounding little pre-amp. Low noise and nice RIAA equalization. It also has a nice D-to-A converter with an USB output. It has a headphone jack for monitoring or listening, and you can use line level inputs too. Mine didn't come with any software, but there is tons of freeware available. I use Audacity,but there are others. I have a kit tube pre-amp that's nearly 4 figures that I ran into the line level inputs and ripped a CD with the UFO-202 and my AVID external A/V card for comparison. Only on a few LP's in a few places could I tell any difference at 48000/16. Biggest bargain and easiest to use "ripper" you'll find.
Date published: 2015-02-18
Rated 4 out of 5 by from Seems good.I purchased this for a friend so I haven't had much chance to listen to it. I was hoping that the preamp would work when powered by the USB port on an AV receiver but it had low and distorted audio at the RCA outputs. It works fine when connected to a PC with the driver installed. It would have been nice if this was addressed in the manual.
Date published: 2014-09-07
Rated 5 out of 5 by from Eas to use. Plug and play.Excellent unit. Performed exactly as stated in instructions. Recorded a few cassette tapes to my I tunes with no problems at all.
Date published: 2014-07-04
Rated 5 out of 5 by from Outstanding ServiceOrdered on Wednesday, received the very next day. Awesome service, right piece at the right price. Highly recommend!
Date published: 2013-05-08
Rated 4 out of 5 by from Great for importing Records and Tapes to Digital FormatI bought this to import some vinyl records onto my computer. It works very well. My only complaint is that the software is no longer included with the device. Although the box still says there is energy XT2.5 Compact included, it is not. PE Technical Advisor directed me to the Behringer Website(http://www.behringer.com/EN/Support/U-Control-Downloads.aspx) for software and driver downloads. The site does not contain energyXT2.5 Compact software! I am using audacity and is no loss for me, but I though others should be aware that you will have to download software to use it.
Date published: 2013-03-23
  • 2016-02-10T06:55CST
  • co_hasreviews, tv_0, tr_12
  • loc_en_US, sid_248-6506, PRD, sort_mostRecent
Does the software work on Windows 8.1 ?
Asked by: Butchb
Yes, and no drivers are required for operation. Windows XP,2000 and higher.
Answered by: TomI
Date published: 2015-01-20
will this pre amp allow me to hook up my turntable and play vinyl thru my Digital Receiver?
Asked by: stevemark3
Yes, if your receiver doesn't have a phono input this will allow a standard turntable to play through it.
Date published: 2014-04-21
phono pre-amp
can i also use this as a regular phono pre-amp, using the RCA output to my receiver?
Asked by: ericjnelson
Yes, the USB interface does not have to be used.
Date published: 2014-03-16
Is it compatible with Win 7?
Asked by: Spike
Almost certainly, USB audio devices usually have a generic interface, requiring no special driver.
Answered by: AlonzoTG
Date published: 2011-08-19
What is the most accessable way to connect Behringer with my stereo EQ
I have 425 watt Carver amp using its tape switch through a 20 slide pod EQ ( the loop) -What would you suggest as my ins and outs for the UFO202 for connection to my desktop?
Asked by: smokey
Unless your are connecting a turntable the UCA202 might work better for this.
Answered by: Froste
Date published: 2011-04-15
  • 2016-02-10T07:38CST
  • co_hasquestionsanswers, tq_5
  • loc_en_US, sid_248-6506, PRD, sort_recentQuestionsFirst
