Behringer UCA222 U-CONTROL 2-In/2-Out USB/Audio Interface
Brand:|Model: UCA222|Part # 248-6504
The fastest, easiest way to get analog audio into your computer is with the U-CONTROL UCA222 Audio Interface. This ultra-compact, USB-powered device lets you connect your PC or Mac computer to virtually any piece of audio gear.
List Price$44.99
You Save33%
$29.99
Part # 248-6504
  • Ultra-flexible audio interface connects your instruments, mixer, etc. with your computer
  • Free download of Tracktion music production software
  • Works with your PC or Mac computer—no setup or drivers required
  • Allows simultaneous digital and analog audio output
  • High-resolution 48 kHz converters for high-end audio quality
  • Stereo headphone output with dedicated Level control lets you monitor both input and output
  • Massive software bundle includes Audacity audio editor and comprehensive podcasting software
The Fastest Way to Upgrade Your Mixer
Looking for a simple, affordable way to get your music into the digital realm? Or maybe you'd like to connect your computer to an external effects unit or recorder? Want to transfer your old cassette tapes to CD before the oxide falls off the tape? The fastest, easiest way to get analog audio into your computer is with the U-CONTROL UCA222 Audio Interface.
PC and Mac Ready
This ultra-compact, USB-powered device lets you connect your PC or Mac computer to virtually any piece of audio gear. It gets its power from your computer's USB bus, so no external power supply or batteries are required. And the UCA222 requires no special setup or drivers—just plug it in to a free USB port and start recording.
Versatility
The UCA222 features two analog mono inputs for connecting any line-level device, such as a mixer or tape deck, and two analog mono outputs for connecting active speakers or studio monitors. On the digital side, the UCA222 provides USB connectivity and an additional S/PDIF optical output for direct analog-to-digital conversion. The stereo headphone output has a dedicated level control and allows you listen to either the input source or the computer output.
Imagine the Possibilities...
When used as a professional interface between a mixing console and your computer, myriad options become available. Some of these might include connecting the UCA222's RCA outputs to the TAPE INPUT jacks of your mixer or active monitors, or directly into the input channels of the mixer. Connecting to mixer input channels gives you access to equalization and allows you to use the AUX Send features of your mixer to build extremely versatile monitor mixes for your recording sessions.
Compose. Record. Mix. Share.
Tracktion puts the fun back into the creative process, so it's included free of charge with select Behringer products. This powerful, yet easy-to-use music production software is unlike anything you've seen before, putting everything you need on your desktop, on a single-screen, without the sea of drop down and hidden menus common to most other DAWs. In addition, Tracktion doesn't limit the number of tracks you can record, or the number of effects you can use. In fact, the only limitation is your Mac or PC computer's processing power. Recording and editing couldn't be easier; simply drag, drop, cut, copy or paste. Once your magnum opus is finished, share it with other "Tracktioneers" so they can listen, collaborate and edit. Visit Behringer.com to register your hardware, and you'll receive a redemption code to download Tracktion at no charge.
Value
For a fraction of the cost of an overpriced USB audio interface from those other guys, you can have state-of-the-art digital conversion, world-class recording and editing software, and hassle-free connectivity between your PC or Mac Computer and any piece of audio gear.
Specifications: • Frequency response: 10 Hz - 20 kHz, ±1 dB @ 44.1 kHz sample rate; 10 Hz - 22 kHz, ±1 dB @ 48 kHz sample rate • THD: 0.05% typ. @ -10 dBV, 1 kHz • Crosstalk: -77 dB @ 0 dBV, 1 kHz • S/N ratio: A/D 89 dB typ. @ 1 kHz, a-weighted; D/A 96 dB typ. @ 1 kHz, a-weighted • Dimensions: Approx. 0.87" H x 3.46" W x 2.36" D • Weight: Approx. 0.26 lbs.
  • BrandBehringer
  • ModelUCA222
  • Part Number248-6504
  • UPC736211578945
  • Product CategoryDigital Audio/Video Converters
    (4 Reviews)
  • Weight0.65 lbs.
View similar products to the Behringer UCA222 U-CONTROL 2-In/2-Out USB/Audio Interface
in the Digital Audio/Video Converters product category.
