248-6736_ALT_0
Behringer TPK988 Bass Trio Effects Pedal with Cables
Brand:|Model: TPK988|Part # 248-6736
The Behringer Bass Trio contains the BCH100 Bass Chorus, BLE100 Bass Limiter Enhancer and BOD400 Bass Overdrive all in one package!
  • Get serious low-end rumble with this set of stompboxes for modern bass guitar sounds
  • The BASS OVERDRIVE BOD400 provides tube-like distortion and super fat tone, with Balance control to blend between overdriven and dry bass sound for maximum punch
  • The BASS LIMITER ENHANCER BLE100 smoothes out harsh volume peaks when using dynamic slaps or other playing styles
  • The BASS CHORUS BCH100 gives you super thick chorus with unbelievable stereo effect
  • Package includes all cables to interconnect the pedals and connect directly to your bass amplifier: 10'' high-quality instrument cable and 2 short patch cables
  • High-quality components and exceptionally rugged construction ensure long life
Frequently Bought Together
The Behringer Bass Trio TPK988 takes the guesswork out of creating a killer effects chain for bass tones. Behringer asked their team of musicians who knows what works best and they put together the BCH100 Bass Chorus, BLE100 Bass Limiter Enhancer, and BOD400 Bass Overdrive. They even included the necessary cabling you need to put these pedals between your guitar and amplifier!
At long last, there's a bass/keyboard chorus pedal that provides super-thick stereo chorusing without sacrificing the lows! The Bass Chorus BCH100 applies a warm, rich chorus to only the upper frequency range of your signal, allowing your bottom-end to retain all its punch and definition. The "secret" is the extremely unique Shape control that lets you determine how much of the low frequency content is affected by the chorus. It functions very much like a crossover circuit, allowing you to keep the bottom-end full and tight, while creating stunning top-end shimmer. The Level control is used to raise and lower the output of the BCH100 and the Rate and Depth controls set the speed and fullness of the chorus effect.
Sound engineers and professional bass players have known for years that high-quality limiting and enhancement makes bass tracks pop in the mix. The Bass Limiter Enhancer BLE100 gives your playing that same velvety finishing touch by smoothing out inconsistent volume peaks. By its very nature, extreme compression tends to suck the high-end out of any signal, so we added a tone compensation circuit to the BLE100. This dedicated Enhance control lets you dial in just the right amount of sparkle, without giving your bass that over-processed or brittle sound. This feature alone will make the BLE100 one of your favorite secret weapons!
Here's an overdrive pedal that supports the entire frequency range of bass guitars, even 5 & 6-stringers. The best part of all, the Bass Overdrive BOD400 was designed specifically for bass, so the bottom-end won’t drop out when you pull the trigger. One of BOD400's coolest features is its Balance control, which lets you mix the overdriven signal with your natural bass sound for superb clarity, punch and extraordinary character. That way you can add the perfect amount of tube-like tone, without sacrificing all of your precious low-frequency content.
  • BrandBehringer
  • ModelTPK988
  • Part Number248-6736
  • UPC4033653180139
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight3 lbs.
View similar products to the Behringer TPK988 Bass Trio Effects Pedal with Cables
in the Guitar & Bass Effects Pedals product category.
