Behringer TP300 Classic Tremolo / Pan Effects Pedal
Brand:|Model: TP300|Part # 248-6398
The TP300 effect pedal by Behringer provides guitarists easy-to-use tremolo and panning effect styles.
Comparable Items In Stock:
Part # 248-6398
  • Dedicated Depth, Rate and Mode controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
Best of Both Worlds
Tremolo—the rhythmic fall and rise of volume—is one of the oldest effects ever applied to musical instruments. Pan—the shifting of the sound signal from the left to the right—is one of the most common tricks used in classic, as well as modern stereo recordings. Now you can add both of these awesome effects to your rig with just a single pedal, the TP300.
Easy to Use
Use the dedicated DEPTH and RATE controls to create a hypnotic pulse, then select from two different types of tremolo or pan. The blue LED tells you when it's on, and the red LED shows the rate by blinking in time with the effect. With its dual inputs and outputs, you can take advantage of a true stereo pan that’s guaranteed to dazzle your audience. The TP300 can be powered by either a 9V battery or our PSU-SB DC power supply (not included).
You don't have to settle for just one, or the other, of these classic stereo effects. Now you can have both, with money left over for even more toys with the very affordable ULTRA TREMOLO/PAN TP300.
Specifications: • Input A/B connector: 1/4" TS • Input A/B impedance: 500k ohms • Input A impedance mono: 250k ohms • Output A/B connector: 1/4" TS • Output A/B impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelTP300
  • Part Number248-6398
  • UPC4033653052542
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.73 lbs.
View similar products to the Behringer TP300 Classic Tremolo / Pan Effects Pedal
in the Guitar & Bass Effects Pedals product category.
