Behringer TO800 Vintage Tube-Sound Overdrive Effects Pedal
Brand:|Model: TO800|Part # 248-6396
Get screaming tube-like distortion, smooth sustain and super-fat tone with our TO800. In order to recreate the authentic vintage sound Behringer used the original 4558 op amp and the legendary MA150 distortion diodes.
List Price$29.99
You Save33%
$19.99
Part # 248-6396
  • Get vintage overdrive, smooth sustain and screaming fat tone
  • Uses original 4558 IC plus MA150 distortion diodes for authentic vintage sound
  • Captures every nuance of your playing from smooth overdrive to screaming tube sounds
  • Dedicated Drive, Tone and Level controls for awesome sound shaping
  • Status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for noise-free operation
The classic sound of blazing, overdriven vacuum tubes never goes out of style. This sound is at your command when you put the TO800 in your effects chain.
Vintage Tube-Like Tone
In order to recreate the sound of real tube crunch, Behringer put the original 4558 op amps and legendary MA150 distortion diodes in this dirt box, putting rock's most powerful sounds at your disposal. The resulting output is very faithful to that of vintage tone machines that made rock and roll history.
So Easy to Use
Dedicated DRIVE, TONE and LEVEL controls let you shape exactly the sound you want. The status LED tells you when this pedal is activated, and its top-quality on/off switch gives you the highest signal integrity in bypass mode. You can power the TO800 via a 9V battery or a PSU-SB DC power supply (not included).
Affordable Vintage Tone
Take charge of the sound that made rock immortal with the VINTAGE TUBE OVERDRIVE TO800! At last, beautiful tube tone is no longer just a pipe dream—and it's oh, so affordable.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelTO800
  • Part Number248-6396
  • UPC689076111812
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.75 lbs.
View similar products to the Behringer TO800 Vintage Tube-Sound Overdrive Effects Pedal
in the Guitar & Bass Effects Pedals product category.
