Behringer TO100 Authentic Tube-Sound Overdrive Effects Pedal
Brand:|Model: TO100|Part # 248-6394
Behringer's TO100 high-quality effect pdeal is ideally suited for giving electric guitars maximum flexibility with state-of-the-art overdrive sounds that capture every nuance of your playing—from smooth overdrive to screaming tube sounds.
  • Get tube-like distortion, smooth sustain and super fat tone
  • Captures every nuance of your playing from smooth overdrive to screaming tube sounds
  • Dedicated Drive, Tone and Level controls for awesome sound shaping
  • Status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for noise-free operation
  • High-quality components and exceptionally rugged construction ensure long life
If the meat n' potatoes of rock n' roll is your taste, you'll live happily ever after on the timeless tone we've packed inside. It just doesn't get any more classic than the Behringer Tube Overdrive TO100.
Tube-Like Tone
Unlike the heavily saturated distortion sounds found in metal- and hard rock-oriented pedals, this little dirt box produces the harmonic grind that naturally occurs when a tube amp is cranked up nice and loud. And the TO100 is extremely versatile and ultra-responsive.
Ease of Use
With its simple DRIVE, TONE and LEVEL dials, you can harness any degree of overdrive from slightly dirty to hot n' crunchy. The blue LED tells you when it's activated, and the durable on/off switch maintains crystal-clear signal integrity in bypass mode. You can power the TO100 with a 9V battery or a Behringer DC power supply (not included).
Designed for use with guitars, bass, and keyboards.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelTO100
  • Part Number248-6394
  • UPC4033653051293
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.75 lbs.
View similar products to the Behringer TO100 Authentic Tube-Sound Overdrive Effects Pedal
in the Guitar & Bass Effects Pedals product category.
