Behringer TM300 Tube Amp Modeling Effects Pedal
Brand:|Model: TM300|Part # 248-6392
The TM300 by Behringer is a high-quality effects pedal that provides 3 classic guitar amps, 3 gain modes and 3 mic placements for a total of 27 configurations that let you easily achieve the most sought-after tube amp sounds from clean, crunch to super-fat distortion.
List Price$37.99
You Save34%
$24.99
Part # 248-6392
  • Provides a truckload of great amps in a single stomp box
  • Dedicated Drive, High and Low EQ, Level, Mic, Model and Amp controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
Setting up amps, dialing in tones and positioning mics takes a lot of time and patience. Why not step on a TUBE AMP MODELER TM300 and skip straight to the good part?
Whazzup?
With three classic tube amps, three (3) gain modes and three (3) mic placements to choose from, the TM300 puts 27 combinations of some of the most sought-after tube amp tones right at your feet!
You Can Have It All
In this one simple pedal, you can call up the sound of a coveted tweed relic, a clean Californian classic or a roaring British powerhouse. You then apply your choice of the three different gain modes, and even control virtual mic placement. And with its dedicated LEVEL, LOW, HIGH and DRIVE dials, the TM300 allows you to take any of these historic tones and shape them into something uniquely all your own.
First-Class Switch
The bright, blue LED tells you when the TM300 is activated, and the top-quality on/off switch maintains incredible signal integrity in bypass mode. You can power this little "jack-of-all-trades" with either a 9V battery or our PSU-SB DC power supply (not included).
Value
Why spend all your time lugging gear, tweaking knobs on multiple amps and playing pin-the-mic-on-the-grill? Get a TUBE AMP MODELER TM300, and do what you do best—make music!
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelTM300
  • Part Number248-6392
  • UPC689076112413
  • Product CategoryGuitar & Bass Effects Pedals
    (2 Reviews)
  • Weight0.73 lbs.
View similar products to the Behringer TM300 Tube Amp Modeling Effects Pedal
in the Guitar & Bass Effects Pedals product category.
