Behringer SX4882 Eurodesk 24-Mic 48-Channel 8-Buss Mixer
Brand:|Model: SX4882|Part # 248-6498
The SX4882 by Behringer is an in-line mixer within a mixer with Channels 1-24 and Channels 25 – 48, it's really two 24-channel mixers in one.
  • Ultra-low noise, high-headroom analog mixer for studio, live, monitor, & so much more!
  • True in-line concept with 24 independent Mix-B input channels
  • 24 state-of-the-art XENYX Mic Preamps with switchable +48 V phantom power
  • Neo-classic "British" 4-band EQs with 2 semi-parametric mid bands for warm and musical sound
  • 8 subgroups with independent Solo and routing functions simultaneously feed 16 multi-track outputs
  • Clip and -20 dB LEDs plus EQ In, Low Cut, Mute, Solo/PFL, Subgroup and Main routing switches
  • 6 Aux sends per channel: all switchable pre/post fader
Frequently Bought Together
Complete Versatility
Whether recording in the studio, running live house sound, recording a live show, or for use as a stage monitor mixing board, the feature-packed SX4882 does it all. Designed with live performance versatility and recording necessities built in, this console combines years of every sound engineer's wants and needs into one high-performance machine. It may not get you free beer or groupies, but it rocks for live-sound and recording.
What is an In-Line Mixer? And Why You Want One
An in-line mixer is a mixer within a mixer. That's the reason you will notice this board is labeled Channels 1-24 AND Channels 25 – 48. It's really two 24-channel mixers in one.
This "embedded mixer," called Mix B, is typically used in recording applications, but it has some useful live-sound features as well. In the studio, Mix B allows you to return all your multi-track tape channels back into channels on the board without losing any of your 24 main-input channels. This provides seamless playback and mixdown capabilites with just a few button pushes and no additional patching. In other words, no visible plumber-cracks or untimely delays. Live, Mix B can be used to send a totally separate 2-track mix to a recording device, separate speaker zone or out to a broadcast feed, plus it functions as an additional monitor or effects bus.
One reason you'll really appreciate having the in-line mixer is simple: LIVE RECORDING. If you've ever tried to make a recording off of the board during a live show, you know how well that works (NOT!). Often input and output levels necessary for quality recording do not match the requirements of the live mix, where stage volumes factor in to the overall room sound. Getting around that issue used to require a splitter and second mixer just for recording. Now that is eliminated by having an in-line mixer in your live board.
Va-Va-Va-Versatility! No More “Creative Patching”
Input choices and routing options are not overrated. In fact, they are essential to managing technically complex instrumentation or multiple bands all patched into the same board. And while you may not need every patching option for every show, at least you know you have every input and output option you could ever need. You will be grateful to have features like Insert points on every channel input, all Subgroups and on the Main outs. Direct Outputs on each channel are very useful too and may even make you a hero for about 5 minutes when you can provide a seemingly improbable solution by taking a direct split off the console to feed some other input source.
Use your creativity where it matters most – in getting the sound and mix you want, not on brain-twisting patching compromises and channel routing puzzles. Complete versatility and accessibility is what it’s all about and the SX4882 does not disappoint.
All Channels Are Indeed Created Equal
There’s no scrimping and saving on this board. Every channel has every feature of every other channel. They are all the same! No more "if only" sighs of frustration to utter as you try to organize your inputs.
As long as we’re talking about channel strips, you might as well know that this board has a big treat in store for you: TWO bands of semiparametric mid range controls. This is two more than many boards offer and at least one more than most live sound boards. Gone is the dilemma of EQ-ing out the honk at 600 or adding a little upper-mid crispness at 2k to bring out the clarity. Now you don’t have to compromise.There’s no scrimping and saving on this board. Every channel has every feature of every other channel. They are all the same! No more "if only" sighs of frustration to utter as you try to organize your inputs.
British EQ for Bloody Excellent Sound
Expensive British consoles have long been praised for having sweeter, smoother channel EQ than many other mixers provide. That’s why the EQ circuitry on the SX4882 is designed with British-style EQ, with wider curves and smoother phase characteristics. It maximizes effective frequency sculpting without harshness or gaping holes in the audio spectrum. This sweet feature will benefit your mixes – both live and in the studio. You may even start saying "Check One, Two" with a British accent. And it’s worth repeating that there are two sweepable EQ bands, not just one. That’s a must-have for many situations, and now you have it!
Mic Pre’s – the Muck Stops Here
The microphone preamp is one of the most important circuits in a mixing console. It boosts the low level microphone signal to a line-level operating level and it's the first bit of processing applied to any mic signal. No doubt you've heard the phrase, "garbage in equals garbage out." This is really true when it comes to mic preamps. Common issues with lower quality mic pres include noise, distortion, low headroom, and unimpressed fans. Behringer uses high quality XENYX preamps in our professional mixers. These are ultra low noise, high headroom preamps that can hold their own, even against expensive standalone boutique-style preamps.
Buttons, Buttons, Buttons
This baby's got buttons. Do buttons look cool? Yes! Is this why they are on the board? No! They're there because you need them all! But many mixers don't have all these options, which may be why some sound technicians are missing a lot of their hair.
One word of caution: You may have to contend with adoring masses asking if you really know what all those buttons do.
PFL/SOLO capability on:
    Every channel, pre- or post-fader option
    Aux bus sends
    Aux returns
    All subgroups
    Headphone mixes
Routing Matrix Buttons & More:
    Select switch that assigns Mix B input OR mic/line input to Main Channel strip
    Mic/Line input select button
    Aux Send Mix B- sends Mix B input source to Aux send
    B-channel Flip switches Mix B input source to mirror main channel input
    Mix B operating input level, +4 dB or -10 dB
    Channel low-cut filter
    Phantom power On, independent 8-channel blocks
    Subgroup and Main Mix assignment
    Channel mutes - on all channels 1-48, including all Mix B channels
Specifications: • Dimensions: Approx. 2.8", 8.7" H x 37" W x 29.5" D • Weight: Approx. 61.2 lbs.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • XLR Mic Inputs24 +
  • BrandBehringer
  • ModelSX4882
  • Part Number248-6498
  • UPC4033653021135
  • Product CategoryMixers - Live Sound & Recording
  • Weight84.0000 lbs.
View similar products to the Behringer SX4882 Eurodesk 24-Mic 48-Channel 8-Buss Mixer
in the Mixers - Live Sound & Recording product category.
