Behringer SU9920 Stereo Sound Enhancement Processor
Brand:|Model: SU9920|Part # 248-6384
Behringer's SU9920 sound enhancement processor works with two independent channels so you can selectively process stereo or two mono signals separately from each other, improving the presence and liveliness of audio signals.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$149.99
You Save33%
$99.99
Part # 248-6384
  • Dramatically improves your sound by adding clarity, dimension, and depth
  • Dedicated Low contour and Process controls per channel for ultimate sound enhancement
  • Accurate 5-segment LED level meters for optimum performance
  • Servo-balanced inputs and outputs with 1/4" TRS and gold-plated XLR connectors
  • High-quality components and exceptionally rugged construction ensure long life
Introducing the Breathtaking SONIC ULTRAMIZER SU9920 from BEHRINGER The SONIC ULTRAMIZER SU9920 stereo sound enhancement processor gives your music the additional dimension you've been looking for. This processor is the ultimate sound improvement tool for home recording studios, DJ systems, keyboard racks, web-casting plus 5.1 and hi-fi setups. The SU9920 provides increased clarity and punchy bottom end to your sound system. It improves the natural brightness through harmonic enhancement and adds density to the low frequencies through phase compensation. Dedicated Low contour and Process controls for each channel enable fast and easy setup as well as ultimate sound improvement. Fasten your seat belt and take off with a new sound dimension!
Sound Quality
The SU9920 provides increased clarity and punchy bottom end to your sound system. It improves the natural brightness through harmonic enhancement and adds density to the low frequencies through phase compensation. Dedicated Low Contour and Process controls for each channel enable fast and easy setup. Once you experience what the SU9920 can do, it will become your go-to sound enhancement tool.
Vibrant Live Sound
The SU9920 is ideally suited for use in all live sound applications, providing noticeable improvement to signal quality and bringing out the very best in your sound system, whether you’re mixing a duo in a coffee house, or dialing a massive outdoor concert.
Sweet in the Studio
In a studio environment, the SONIC ULTRAMIZER is ideal for enhancing the sound of your mastering recordings. The SU9920 can give your music the professional polish of high-quality productions in just a few simple steps. Even if you primarily work with a digital audio workstation, you can perform final mastering with the SU9920 and an external recorder.
Versatility
In addition to being great for use with stereo signals, the SONIC ULTRAMIZER is also ideal for use with individual signals, such as guitar, keyboards or bass. Just connect the SU9920 into the signal path, or use your amp’s effects loop, for sound with more presence, fullness and punch. Since the SU9920 can be run in stereo or dual mono, you can even use one side for the bass, the other for a keyboard or guitar.
Getting Connected
All inputs and outputs accept balanced XLR as well as balanced and unbalanced 1/4" connections. Both the 1/4" and XLR outputs can be used in parallel, when two outputs are required.
The Technical Stuff
The SU9920 boasts stellar frequency response from 25 Hz to 50 kHz. The Process control provides a boost of up to +12 dBu at 5 kHz. The Low Contour filter is capable of +12 dBu at 50 Hz.
Specifications: • Frequency response: 25 Hz - 50 Hz, ±3 dB •/ S/N ratio: >95 dB, unweighted, 20 Hz - 20 kHz • Distortion: 0.05% typ. @ +4 dBu, 1 kHz • Crosstalk: >75 dB • Dimensions: Approx. 1.75" H x 19" W x 8.54" D • Weight: Approx. 4.85 lbs.
  • BrandBehringer
  • ModelSU9920
  • Part Number248-6384
  • UPC736211577146
  • Product CategoryEffects Processors / DSP Modules
  • Weight6.95 lbs.
View similar products to the Behringer SU9920 Stereo Sound Enhancement Processor
in the Effects Processors / DSP Modules product category.
