Behringer SP400 Phase Shifter Effects Pedal
Brand:|Model: SP400|Part # 248-6728
The SP400 phaser delivers the entire history from vintage to modern phone shifting effects. Experience sounds from classic multi-stage phasers to new swirling up and downward moving sounds.
  • The ultimate Phase Shifter that delivers the whole history from vintage to modern phase shifting effects—at the touch of a footswitch
  • Real Sound Modeling (RSM) combines state-of-the-art DSP technology with sophisticated algorithms to emulate real acoustic environments
  • Experience any sounds from classic 4-, 8-, 10- and 12-stage phasers to new swirling up- and downward moving sounds
  • Dedicated Mode, Resonance, Depth and Rate controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
Frequently Bought Together
There's always a place in your pedal chain for the SP400 super phase shifter from retro psychedelic all the way to laser-guided metal, . The SP400 lets you experience the phasing styles of classic multi-stage phasers plus completely modern sounds. This phaser filters a signal by creating a series of peaks and troughs in the frequency spectrum. The position of the peaks and troughs is modulated so that they vary over time, creating a sweeping effect. In plain terms, the SP400 will make your guitar sound something like a jet airplane flying overhead.
Real Sound Modeling (RSM) technology, which has been integrated into this pedal for the first time, gives the SP400 the power to create a wide, rich tonal palette. Go from gentle tone coloration to really deep phasing. Every step along the way sounds like it was created in a state-of-the-art studio!
The SP400 SUPER PHASE SHIFTER has a Fall, Rise, Step, 4-, 8-, 10-, and 12-step Mode switch plus Resonance, Depth and Rate controls. Other features are the Tap Tempo option, a dazzling blue LED to indicate the power status and battery condition plus the bypass footswitch, which preserves signal integrity. You can power this pedal with a 9V battery or a DC Power Supply (not included).
Specifications: • Input/output connector: 1/4" TS • Input impedance: 500k ohms • Output impedance: 1k ohm Exp/Ctl connector: 1/4" TS • Ext/Ctl impedance: 500k ohm • Power supply: 9 VDC, 100 mA, regulated; 120V~, 60 Hz • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Power consumption: 30 mA • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.35 lbs (0.77 kg).
  • BrandBehringer
  • ModelSP400
  • Part Number248-6728
  • UPC4033653053273
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.88 lbs.
View similar products to the Behringer SP400 Phase Shifter Effects Pedal
in the Guitar & Bass Effects Pedals product category.
