Behringer SO400 Octaver Effects Pedal
Brand:|Model: SO400|Part # 248-6726
Behringer's SO400 is the ultimate octaver with polyphonic input and the capability of creating octaves 1 and 2 octaves below the original tone.
  • The ultimate octaver with Polyphonic Octaves function for processing polyphonic input—one octave below the lowest note
  • Real Sound Modeling (RSM) combines state-of-the-art DSP technology with sophisticated algorithms to emulate real acoustic environments
  • Take off with ultra-stable mono- and polyphonic octaver sounds plus an aggressive Drive mode for fat overdrive sounds
  • Dedicated Mode, Range/Oct 2/Drive, Oct 1 and Direct controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
We know you put a lot of time and tweaking into making your tone what it is. The SO400 preserves that tone while complementing it with beautiful low tones produced by Behringer's Real Sound Modeling (RSM) processor. This state-of-the-art technology is the actual star of the show, giving you sound quality found in high-end studio processors. It generates up to two additional signals, one and two octaves below your single notes, respectively. That's some massive bottom-end! And by switching to its Polyphonic Octaves function, you can even super-size chords into bursting clusters.
This first-class pedal features two creative controls: Octave 1 plus a rotary knob switchable between Range, Octave 2, and Drive settings. You can also feed the unprocessed signal out to other Behringer processors with output level control via a separate Direct knob. The unit includes separate Bass and Guitar inputs, separate Direct output, a shining blue LED to indicate the power status and battery condition plus an electronic footswitch, which preserves signal integrity in bypass mode. Use a 9V battery or our Behringer PSU-SB DC power supply (not included) to run the SO400 effects pedal wherever you like.
Specifications: • Guitar/Bass input connector: 1/4" TS • Guitar/Bass input impedance: 500k ohms • Direct output connector: 1/4" TS • Direct output impedance: 1k ohm • Power supply: 9 VDC, 100 mA, regulated; 120V~, 60 Hz • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Power consumption: 30 mA • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs (0.33 kg).
  • BrandBehringer
  • ModelSO400
  • Part Number248-6726
  • UPC4033653053259
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.88 lbs.
View similar products to the Behringer SO400 Octaver Effects Pedal
in the Guitar & Bass Effects Pedals product category.
