Behringer SM400 Super High-Gain Distortion Effects Pedal
Brand:|Model: SM400|Part # 248-6380
The SM400 stomp box by Behringer is one hot piece of gear that gives you increasing distortion drive, intense sustain and the roaring sound of an overdriven stacked tube amp when slamming down the pedal.
  • Dedicated Distortion, 2-band EQ and Level controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
In the world of heavy metal, there is no such thing as too much of a good thing. In this case the "good thing" is pure metal distortion—and the Super Metal SM400 definitely delivers.
It's All About Tone
The SM400 stomp box is one red-hot piece of gear that gives you increased distortion drive, intense sustain and the roaring sound of a tube stack cranked to the max!
Sublimely Simple
Twist the dedicated LEVEL, LOW, HIGH and DISTORTION dials to create a sound that'll make your hottest licks chug, sustain and just plain kill. The blue LED tells you when it's working, and the top-quality on/off switch maintains incredible signal integrity in bypass mode. You can power this metal maniac with a 9V battery or our PSU-SB DC power supply (not included).
Value
Step up to the edge, and then throttle righteously into the metal abyss with the ultra-affordable SUPER METAL SM400.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelSM400
  • Part Number248-6380
  • UPC4033653052641
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.73 lbs.
View similar products to the Behringer SM400 Super High-Gain Distortion Effects Pedal
in the Guitar & Bass Effects Pedals product category.
