Behringer RV600 Reverb Modeling Effects Pedal
Brand:|Model: RV600|Part # 248-6724
Deliver 24-bit high-resolution stereo reverbs comparable to state-of-the-art studio processors with the RV600 effect pedal.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
Ships in 7-10 Business Days
List Price$74.99
You Save33%
Part # 248-6724
  • The ultimate Reverb Modeler that delivers the whole history from classic spring reverbs to high-end studio reverbs—at the touch of a footswitch
  • Real Sound Modeling (RSM) combines state-of-the-art DSP technology with sophisticated algorithms to emulate real acoustic environments
  • Experience any reverbs from Spring, Plate, Room, Hall, Ducking, Echo to Space sounds that you have never heard before
  • Dedicated Mix, Decay, Time, Type, Tone and Trails controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
Frequently Bought Together
From sopping-wet spring reverb to state-of-the-art echo, the complete evolution of this timeless, haunting effect awaits you in the Behringer Reverb Machine RV600. With 11 well known modes and the extensive parameter control that allow for maximum creativity, you'll have plenty of great sounds at your disposal for every situation.
Reverb emulates the natural echo that occurs because of an environment's acoustics. Think of how your guitar would sound if you plucked a note while standing in a big empty gymnasium – the RV400 can produce that sound, even if you're playing in your bedroom!
The RV600 contains Behringer's Real Sound Modeling (RSM) processor and DSP technology, giving it the incredible power to make your guitar sound like you're playing in a cave, a cathedral, or even the outer reaches of the cosmos. With this pedal, putting studio-caliber sound in your signal chain is easier than ever before.
Just twist the dedicated dial to select dead-on modeling of Ducking, Space, Cave, Tile, Echo, vintage '63 Spring, Spring, Plate, Room, Chamber and Hall reverbs. Tweak the dedicated Mix, Decay, Time and Tone controls along with the Trails On/Off switch to create reverb that is resonant, abrupt, or just plain otherworldly! The brilliant blue LED tells you when it's working while the top-quality on/off switch preserves the signal integrity in bypass mode. You can power this stomp box with a 9V battery or a DC power supply (not included).
Specifications: • Input A/B & Output A/B connector: 1/4" TS • Input A/B impedance: 500k ohms • Output A/B impedance: 1k ohm • Input A impedance mono: 250k ohms • Power supply: 9 VDC, 100 mA, regulated; 120V~, 60 Hz • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Power consumption: 30 mA • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs (0.33 kg).
  • BrandBehringer
  • ModelRV600
  • Part Number248-6724
  • UPC689076146814
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.88 lbs.
View similar products to the Behringer RV600 Reverb Modeling Effects Pedal
in the Guitar & Bass Effects Pedals product category.
