Behringer PSU-SB General Purpose 9 VDC Power Adapter
Brand:|Model: PSU-SB|Part # 248-6354
Use Behringer's general purpose 9 VDC power adapter PSU-SB to power virtually any of your guitar or bass guitar stomp boxes and effects pedals.
- Order Soon - Only 3 Left In Stock
List Price$14.99
You Save33%
$9.99
Part # 248-6354
  • Converts to DC 9V for use with virtually all stomp boxes and effects pedals
  • Typical DC-type 2.1 mm plug with negative tip and positive sleeve
  • Provides a generous 100 mA current to power even digital products
  • High-quality components and exceptionally rugged construction ensure long life
This adapter provides a generous 100 mA current to power even digital products. For connection, it features a typical DC-type 2.1 mm plug with negative tip and positive sleeve. This universal power supply gives you ultimate power for your most demanding gigs.
• Power output: 9 VDC, 100 mA • Input requirements: 100~240 VAC, 50/60 Hz • Plug tip size: 2.1 x 5.5 mm • Polarity: Center-negative (-).
  • BrandBehringer
  • ModelPSU-SB
  • Part Number248-6354
  • UPC689076426459
  • Product CategoryPedal Boards & Power Supplies
    (1 Reviews)
  • Weight0.25 lbs.
View similar products to the Behringer PSU-SB General Purpose 9 VDC Power Adapter
in the Pedal Boards & Power Supplies product category.
Behringer PSU-SB General Purpose 9 VDC Power Adapter is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from Great pedal power supply!I am new to special effects pedals for guitars. I found out very fast that each pedal can and does consume batteries at an astounding rate. Enter "Behringer PSU-SB General Purpose 9 VDC Power Adapter", what a life and wallet saver!So far, it is churning out the power for three to four pedals depending on the configuration. Now three or four pedals fed from a single source may not sound like much, but when you figure in 9-volt batteries at three to four dollars each being replaced at least every two days ($12.00 -$16.00) this jewel pays for its self on the very first battery change.The price is right, the convenience of use is right, and the Dependability of the Behringer name is right, so do the right thing and save money and time. Just think, your best song that you have poured your soul into, the entire world is watching you and you forgot to check the battery..no power..no release! Make this scenario a thing of the past and double ensure your best performance. A battery in the pedal, the Behringer power supply plugged in. No matter what happens you still have power to your pedal.
Date published: 2009-12-20
  • 2016-02-11T06:44CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_248-6354, PRD, sort_mostRecent
Cost? How much
Asked by: jamesarputharaj
These cost $9.99.
Date published: 2015-03-13
What are approximate dimensions of this power supply? It has to fit in small area. Can you please measure? Thanks, Jeff
Asked by: Nahuntahaven
The overall size of the body of this adapter is 1-1/2"W x 2-3/8"H x 1"D not including the prongs of the plug or the strain relief for the cord. The picture for this item is not accurate.
Date published: 2014-04-28
Will this work with Behringer Minimon mon800. It should be rated at 9v 750 mA
Asked by: Irene's Dream
Unfortunately no, this only supplies up to 100 mA. I would recommend the product below using the 9VDC setting and 2.1mm x 5.5mm plug wired in reverse polarity.
Date published: 2013-11-05
  • 2016-02-11T07:18CST
  • loc_en_US, sid_248-6354, PRD, sort_recentQuestionsFirst
