Behringer PO300 Power Overdrive Effects Pedal
Brand:|Model: PO300|Part # 248-6342
The PO300 stomp box gives you phat and big overdrive sounds with the heavy low-end punch of a tube-driven 4 x 12" cabinet.
  • New type of overdrive circuit offers bigger and fuller sound with endless sustain and compression
  • Dedicated Drive, Power, Phat and Level controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
When a song just screams for solos that tear straight into the heart and power chords that can level stadiums, it's time to shift up to the POWER OVERDRIVE PO300.
Phat Tone
The PO300 pedal's high-octane overdrive circuit gives you big, phat overdrive tone, with the heavy low-end punch of a tube-driven 4 x 12" cabinet—just before meltdown.
So Easy to Use
The dedicated PHAT dial lets you boost the low end, creating bass frequencies that hit you squarely in the chest. Meanwhile, a POWER control lets you add a sweet, sparkling high end. It all adds up to gale-force tone with incredible sustain and streamlined compression. A dazzling blue LED tells you when the motor is running, while a top-quality on/off switch maintains the highest signal integrity in bypass mode. This high-performance vehicle runs on our PSU-SB DC power supply (not included) or a 9V battery.
Value
The POWER OVERDRIVE PO300 will boost your performance with revved-up lows and supercharged highs, without draining your budget.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelPO300
  • Part Number248-6342
  • UPC4033653052580
  • Product CategoryGuitar & Bass Effects Pedals
    (1 Reviews)
  • Weight0.73 lbs.
View similar products to the Behringer PO300 Power Overdrive Effects Pedal
in the Guitar & Bass Effects Pedals product category.
